hi all,
Just had my car(r34 gtt) go thru a major service (timing belt water pump etc) and have run into an issue.
The slip and tcs lights stay on. And I have the MIL light lit up. When I check Nissan data scan I get the error code being Code 13: Engine coolant Temperature Sensor Circuit(P0115).
All genuine parts (Nissan) were used. Car starts fine sounds fine but these issues exist.
The work was all done by a local garage where I live, car didn't have any problems prior to taking it there.
If anyone has any suggestions I'd be grateful to hear.
https://www.sau.com.au/forums/topic/457030-trouble-after-major-servicer34/
It's probably throwing all the lights on because not having a water temp reading will make the car run like shit. The R34 will throw lights on at the drop of a hat.
Give the workshop the benefit of the doubt, if they seem like they're scratching the bottom of the barrel then take it somewhere else. Coolant temp sensor should not be hard to chase.
What area do you live in?
