Hi all
I am now back in Melbourne and living in Brighton so if any of you see a blue RX Liberty around the area give us a wave. I need a skylinesaustralia sticker for it as well so if any of you know where I can get one, let me know.
Hope to see some of you about in the not too distant future :P
https://www.sau.com.au/forums/topic/45704-hello/
hey Alan,
I'm also back in melb now after touring europe for the past 2 months :-)
I'll look out for your liberty if you look out for my wife maxima or my black R33 ;-)
It would be good to meet up after missing each other in the UK.
https://www.sau.com.au/forums/topic/45704-hello/#findComment-933691
ant95gtr - sounds good mate, let us know when
nismor34 - thanks for the link mate, I tried to buy one but as I am on a work PC, the cookies are disabled! My PC at home has a virus so is being fixed, any chance someone can buy one and I pay them! I looked for a phone number for the company but there isnt one I could see.
Look forward to seeing you guys soon.
https://www.sau.com.au/forums/topic/45704-hello/#findComment-935204
    • Ok awesome! I’m not running a aac/iacv (although I do have the r34 iacv but I’m running the heater core loop. I’m running the chase bays booster delete so In that case would I need to block off those posts? So at the moment I need to run from one of the posts to the fpr and then a separate post to the boost controller then to the wastegate? Also I’m assuming that each port has a specific use like the first one farthest to the left would be (for example) manifold to fpr and then second would be to boost controller?
    • I was just going through this on Neil's car (33 gtst). Assuming you are using standard AAC and Cold start valves, you need Post Turbo Pre throttle to Boost Controller (if you have one) then to Turbo Wastegate Pre throttle to AAC input AAC input T piece to Cold start input Cold start output to plenum post throttle AAC Output to plenum post throttle AAC Output to brake booster (needs a 1 way valve) Plenum post throttle to Fuel Pressure Regulator Plenum post throttle to Blow off valve signal Plenum post throttle to Boost controller input (if you have one)
    • I’m trying to figure out the purpose of these fittings. Assuming they’re for coolant but not sure where the lead to. I know the bigger one on the right (which isn’t filled) is the brake booster. If anyone has a photo of a diagram of this intake or has a set of instructions it’d be greatly appreciated
    • How much is that r32? Is that $170k or $1.7m
    • Ahhh! My silly brain was thinking Nissan started selling them straight away, but they waited w or three years didn't they?   Maybe Duncan should build an R35 race car over the V37... There's a cheap yellow one on car sales Duncan, would only need your splash of purple added...
