I have read the many forums about the pro's of doing this mod, so I bought myself a spare pipe from Ebay and had the divider put in.
Does it feel any different? Not sure. The weather is cold so it's very responsive anyway at the moment.... Might be placebo effect but it feels more punchy from 2-3.5K. On boost feels the same.
My question is:
Did you notice the turbo spool noise inside the cabin become more pronounced? I noticed that the turbo's "sound" quite different inside the cabin. Slightly more whiney/whizzy i suppose.
Since your car makes a million horsepower If it's good enough for you it's good enough for me
It's a very lazy design from Nissan, regardless. It makes a huge difference. I have done a back to back test with Marko_R1's car. 3.0 and -10's. Without it, it chided like a steam train. With it, 90% of the shuffle went away. GT-RS's suck dick either way, but that is a first hand experience.
There are NO downsides to doing this mod.
Would be good to see a before and after dyno run if anyone has done it.
+1, or even a flow check/pressure drop measurement of each.
Downside could be lower bang for buck than some other mod, when using smaller non-shuffling turbos. Piggaz - would you do this on a car with stock turbos? -7s?
Was planning to do a before and after on Daz's car, as he plans to run one if it helps with flow. Should help even on a stock car as the front turbo entry is pretty bad.
Cheap and inconspicuous, I like those kind of mods.
Micko's old man just threw this pipe on his -9/stock engine GTR. From the seat of the pants it feels a little more linear.
If you look at the pipe, the front turbo air is basically "merging" at a right angle to the incoming air from the rear huffer.
I believe Sean Morris did a back to back years ago. He was claiming 8-10 hp increase from memory. Have a search online. You should be able to find it. I can't remember the turbo setup he tested it on though.
Just do it, put it on and forget about it.
  • Like 1
here's a picture of my first gtr back in 2004, it had a polished cusco hot pipe and from memory it was very well made and I'm pretty sure when I looked inside it the merge was better than 90 degrees more like 45 degrees and it looked just a smidge bigger in diameter also.
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
