Hi guys, I have a 32 GTR with a few mods, nistune, 34 afms, unsure on turbos (only just got the car), built motor, 34 crank, camtec cams, etc etc,
The car is running very rich and stalls when I come up to a set of traffic lights, it is running standard bovs, would a vacuum leak cause this to happen? What is generally the cause of a vac leak in an RB26? Are there any common hoses that deteriorate quicker than others?
Thanks!!!
Vac leak would make it run lean when off boost if the leak is in the inlet manifold . rich if its a boost leak in a cooler pipe.
Did it always do it@
You should really take it somewhere and run it on a Dyno to check it out.
You have the stock bov's but are they actually functioning correctly and plumbed back? If they aren't that is probably your issue.
Run it on the dyno or do a smoke test to find your leaks after checking the BOVs. It could be poorly tuned also contributing with the leak resulting in the car stalling.
Thanks for the help guys, the car previously made 400rwkw then has been put into storage for a while and there are now a few issues to sort out. What vac lines are under the plenum that could have perished or might be leaking???
well a smoke test is the best way to get to find a vacuum leak, but it requires specialist equipment. Easiest thing to do is to give it to someone who does this all the time unless you are familiar, there are billions of pipes and they won't be standard on your setup
As far as finding it yourself, I'd start with the main intercooler pipes in the engine bay and under the front bar, they are by far the most likely. They check the BOV return lines wherever they plumb back in. Then the boost controller lines and their attachment to the wastegate. Then however your AAC is linked up, that should cover most of the vacuum lines.
If you don't know what it is don't touch it? Got a workshop around that is experienced with Skylines that can help you out? Smoke test and getting the vehicle on a hoist will help significantly.
I'd still put money on it being the BOVs or a combination of BOVs being not plumbed back, broken and the ECU tune being rich to begin with.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
