1993 R32 Skyline Gtst Coupe
Have owned this car for 6 years. Selling due to funds for another project
211rwkw 16psi Stock RB20det
5 Speed RB20 box with EXEDY HD Clutch
T3T4 Highmont SS manifold
Turbo braided Lines
Tial 38mm external gate
Custom intake plenum
FMIC
52mm Alloy Radiator
3" exhaust
HID 8000K
EMS Stinger ECU MAP sensor
AU Falcon Ignition
Deatschwerks 440cc Injectors
Turbosmart Boost gauge and Single stage controller
HKS turbo timer
Bosch040 on 98 pump fuel
Stock suspension on standard R33 Wheels with good tread all round
Running a bit rich at the moment. Will need a retune
157XXX KMS
Genuine plastic Type M Sideskirts and Rear Pods
Body is a little rough few dents.
Shaved bootlid
Paint on roof has faded clear
RH mirror is gun metal colour
Front bar has slight crack
Have spare parts to go with the car
Front brakes need to be bleed
Timing belt/Waterpump changed at 150000KM
Rocket cover gaskets replaced
Oil service changed every 4000KM
No Oil or water leaks
Few other things not listed. MSG/PM for more info
Last tune was done by SMDworkshop
NO REGO. NEEDS PINKSLIP- CAN BE PROVIDED IF BUYER IS 100% FOR PURCHASE. Expired 4th April 2015
Plates will NOT be sold with car!
GENUINE BUYERS ONLY. TIME WASTERS WILL BE IGNORED!!
Location - BASS HILL, SYDNEY
Was $6200 ONO
Now $6000 firm. Need this gone!
Edited by Lemzki
https://www.sau.com.au/forums/topic/457073-for-sale-r32-gtst-210rwkw/
  • 1 month later...
-UPDATE-
NO REGO. NEEDS BLUESLIP. OR CAN BE USED FOR TRACK -
SELLING AS IS. TOWING RECOMMENDED
Posted $6200 ONO
WAS $6000
NOW $5500 NEG
URGENT SALE!
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
