1x R33 APEXi Power FC (model serial no: PFC ECR33 010-1098)
1x APEXi Power FC hand controller (model serial no: FCC3 020-08934)
1x GReddy PRofec B-spec II (complete with wiring harnesses and solenoid)
Removed from a running 1995 R33 GTST Series 1.5 RB25DET to upgrade to a Haltech ECU.
The ECU came with the car when I bought it three and a half years ago. I bought and installed the PRofec B at that time. I had it all re-tuned in May 2012 when I installed 850cc Denso injectors and a GCG Hi-Flowed R34 turbo. That setup made 260 rwkw on pump 98 at 18-19 psi, we maxed out the stock valve springs as they were noisy with any more boost.
I've upgraded to a Haltech Platinum Pro Plug-In ECU with built in boost control so I have no need for these.
The tune currently on it is for stock R33 GTST RB25, stock (pink label) MAF, 850cc Denso injectors, front mount return flow intercooler and GCG hi-flowed turbo. Plus fuel pump and other supporting mods of course.
As the package does include the hand controller it is possible to reset the ECU back to factory settings to plug into a car that is stock as a rock and have it work on a base tune. It's unlikely that you have the same mods as I did to be able to use the tune it has now, mainly the 850cc injectors etc.
Price: $1,150
Where: McDowall, QLD
How: Pickup preferred but will post at buyers expense.
Contact: PM or mobile 0 4 0 2 2 3 2 5 5 6 or email brettd at qubitonline dot com
Any questions feel free to ask in this thread.
I have a couple of people interested in just the ECU and hand controller so if that happens I'll hit you guys up about the boost controller.
Look like the Power FC and hand controller is sold, getting picked up today so $200 plus post for the Profec B boost controller.
Sold to me :)
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
