1x R33 APEXi Power FC (model serial no: PFC ECR33 010-1098)
1x APEXi Power FC hand controller (model serial no: FCC3 020-08934)
1x GReddy PRofec B-spec II (complete with wiring harnesses and solenoid)
Removed from a running 1995 R33 GTST Series 1.5 RB25DET to upgrade to a Haltech ECU.
The ECU came with the car when I bought it three and a half years ago. I bought and installed the PRofec B at that time. I had it all re-tuned in May 2012 when I installed 850cc Denso injectors and a GCG Hi-Flowed R34 turbo. That setup made 260 rwkw on pump 98 at 18-19 psi, we maxed out the stock valve springs as they were noisy with any more boost.
I've upgraded to a Haltech Platinum Pro Plug-In ECU with built in boost control so I have no need for these.
The tune currently on it is for stock R33 GTST RB25, stock (pink label) MAF, 850cc Denso injectors, front mount return flow intercooler and GCG hi-flowed turbo. Plus fuel pump and other supporting mods of course.
As the package does include the hand controller it is possible to reset the ECU back to factory settings to plug into a car that is stock as a rock and have it work on a base tune. It's unlikely that you have the same mods as I did to be able to use the tune it has now, mainly the 850cc injectors etc.
Price: $1,150
Where: McDowall, QLD
How: Pickup preferred but will post at buyers expense.
Contact: PM or mobile 0 4 0 2 2 3 2 5 5 6 or email brettd at qubitonline dot com
Any questions feel free to ask in this thread.
I have a couple of people interested in just the ECU and hand controller so if that happens I'll hit you guys up about the boost controller.
Look like the Power FC and hand controller is sold, getting picked up today so $200 plus post for the Profec B boost controller.
Sold to me :)
    • Happy new years folks! Wishing you all a successful year of money pit ownership!  So the subframe bushes are out....   Ok, who else has done that job before??  What a C U Next Tuesday of a job that is!  Be glad to not do that again in a hurry! I think I explored every option available to chop the middle section of the bushes out, most of them unsuccessfully! I dried a holesaw, die grinder, normal drill bit, air chisel, etc, etc. The true success happened by accident when I'd decided to try a step drill I spotted on the bench on the way passed.  See, there are benefits to never cleaning up after yourself! It RIPPED through so so much better than the drill bit. It has to be the skinniest one available so its small enough to fit between the inner tube and outer casing but it made easy work of it.  First one i hammered the shit out of... New method- 20250102_185506.mp4     I did the other 5 in less time than I fluffed around with the first one. I used the cut off saw (sawsall as the yanks love to call them) to cut a break in the casing. Even with that they're still a prick to hammer or air chisel out.  The last few i just went rambo with the air chisel without cutting them. I overcome one of the early ones so will hit the with the mig to fill the cut then sand it off smooth.  The carnage left over-   I've also been "nesting" ie, cleaning up my babies nursery,  ie cleaning the f**king pig sty of a shed. I've got that much shit laying around it's as cluttered as my head!  Getting things put away, in boxes, on shelves, hanging off walls, all to get some working space back again.  Hopefully that keeps me motivated....
    • AFAIK does the base map for Haltech even have the 4D compensation enabled? It's been a while but when I looked at it I remember it was actually using pure TPS as one load signal and MAP for another. Seemed workable but not ideal by any stretch. A lot of people have "make the event-itis" which leads to stuff like this happening.
    • https://www.youtube.com/watch?v=qHhWelSBppY
    • Even back in the day, some importers were renowned for bringing in crashed cars, giving them a quick touch up + respray and making them look mint
    • No new updates from the op after covid, hopefully everything is ok...
