It's more than likely that they do. They'd be based around the idea of detecting the -OH group on the ethanol, and so should be able to see the same group on the methanol molecule. I would be VERY HESITANT to trust that the % it read out while seeing methanol would be accurate though. I'm sure that there are some calibration factors assumed/built into the sensor or its calculation that would be thrown out by the lighter metho molecule.
I just googled around a bit and there is muttering that the usual suspect sensor (the GM/Haltech one) tends to go to 200Hz frequency when methanol is present - meaning it is not useful. This is not the final word, as I'm not going to do all your research for you, but it would appear that whilst methanol will affect the sensor in a similar way to ethanol (as I suggested in my first post) the actual response of the sensor to the difference between eth and meth is to say that >100% ethanol is present. This is probably the safe and conservative way to do it, because methanol requires a lot more volume than even ethanol does, and system/sensor designers would probably want to be able to protect themselves against people using methanol deliberately/accidentally and running too lean.
Lol, easier to carry a flex fuel sensor
I agree, until such time it lets you down.
I was told these sensors are actually reading what percentage isn't ethanol, not sure how correct this is.
  • Like 1
How many have you seen fail, Scott?
None, and I assume they are fairly reliable seeing they are used in OEM applications, but they are also monitored by the stock ecu, and there are huge safety margins in place. I don't think I could ever fully rely on a sensor like this for turbo tuning unless I had two of them to compare. The less variables in the tune the better imo.
Same goes for wideband target mapping, without a pair of sensors running simultaneously you would have no idea if they are accurate.
But most ECUs have a failsafe, so if the ethanol sensor fails then assume ethanol content is 0% or whatever you set it as.
I'm running a flex sensor now too, drove to Wakefield yesterday with four jerry cans. After the track day, drove to 7-11 and filled up with 98 and drove home.
And unrelated, I chopped two R34 GT-Rs down the straight at Wakefield...
We did the same thing in Artz's 33, other than we had to drop the petrol tune on with the laptop near the border. A simple switch would have done the job.
Doesn't make much difference, you still need two tunes, but I can see the practicality of it.
Yeah but make a perfect 98 tune, then all you do is interpolate between the E85 3D map based on the ethanol content.
I drove home on about E40.. got mad economy too, did 187km on 20L
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
