It's more than likely that they do. They'd be based around the idea of detecting the -OH group on the ethanol, and so should be able to see the same group on the methanol molecule. I would be VERY HESITANT to trust that the % it read out while seeing methanol would be accurate though. I'm sure that there are some calibration factors assumed/built into the sensor or its calculation that would be thrown out by the lighter metho molecule.
I just googled around a bit and there is muttering that the usual suspect sensor (the GM/Haltech one) tends to go to 200Hz frequency when methanol is present - meaning it is not useful. This is not the final word, as I'm not going to do all your research for you, but it would appear that whilst methanol will affect the sensor in a similar way to ethanol (as I suggested in my first post) the actual response of the sensor to the difference between eth and meth is to say that >100% ethanol is present. This is probably the safe and conservative way to do it, because methanol requires a lot more volume than even ethanol does, and system/sensor designers would probably want to be able to protect themselves against people using methanol deliberately/accidentally and running too lean.
Lol, easier to carry a flex fuel sensor
I agree, until such time it lets you down.
I was told these sensors are actually reading what percentage isn't ethanol, not sure how correct this is.
  • Like 1
How many have you seen fail, Scott?
None, and I assume they are fairly reliable seeing they are used in OEM applications, but they are also monitored by the stock ecu, and there are huge safety margins in place. I don't think I could ever fully rely on a sensor like this for turbo tuning unless I had two of them to compare. The less variables in the tune the better imo.
Same goes for wideband target mapping, without a pair of sensors running simultaneously you would have no idea if they are accurate.
But most ECUs have a failsafe, so if the ethanol sensor fails then assume ethanol content is 0% or whatever you set it as.
I'm running a flex sensor now too, drove to Wakefield yesterday with four jerry cans. After the track day, drove to 7-11 and filled up with 98 and drove home.
And unrelated, I chopped two R34 GT-Rs down the straight at Wakefield...
We did the same thing in Artz's 33, other than we had to drop the petrol tune on with the laptop near the border. A simple switch would have done the job.
Doesn't make much difference, you still need two tunes, but I can see the practicality of it.
Yeah but make a perfect 98 tune, then all you do is interpolate between the E85 3D map based on the ethanol content.
I drove home on about E40.. got mad economy too, did 187km on 20L
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
