It's more of an anything that's not petrol sensor, it's reading the ratio of petrol not ethanol. So if you get e85 then add 5% water it should read as e90, as demonstrated at the sau/wolf e85 tech night last year. As long as methanol mixes with petrol and doesn't separate i don't see an issue. If you're using this for water/meth injection then it won't work as the sensor can't differentiate the two. You should probably look into the effects methanol has on certain metals and decide if the sensor will cope.
Edited by linkems
yeh, steve had that, then we did wmi, and ended up with 2 degrees more timing on wmi, but same power as his ignition system was a joke and flatlined up top
both setups did 30 psi and took 20-22 degrees of timing on 98 wmi and 98 +10 percent meth
Ive used e85 and wi together aswell
Im building another car atm. Will be wmi..but if can't get to 35psi ish on just pump 98..ill be doing the same as your planning...f**k e85..i want to drive it everywhere..not to one random servo 40 minutes away..
plenty of other people have played with it in more quantity when e85 coudnt be bought for a while ...I think 60 percent meth/40 percent 98 is close to e85. But you probally dont need that much octane..
how much wmi your spraying atm? what fuel to wmi percentage?
cheers
darren
Edited by jet_r31
Darren, Im only running around 8% of total fuel in WMI, im soon to test with a second nozzle and up to 15%.
Yea the amount of E85 available in SA servos is crap, and none at all in country areas, so thats why im wanting to do the meth flex fuel.
Do you know much about the sensors, and if they would work from 0 to 15% meth/pump mix?
I cant get a clear answer anywhere on this
thats f**kall....i run 20 percent with a 50/50 mix.
Nah can't help with the sensor, i have no idea. ll just do as scott said and mix it up as i use it if i have to go that way, but i think i'll have traction issues before i get to that level
cheers
darren
My understanding is the sensor measures whats petrol and convert it back to whats left as E85.
So if it reads 30% petrol content it displays that as E70 (converts it over as the balance being ethanol)
And having said that, they can be tricked and are therefore highly inaccurate in situations where the fuel may be contaminated with water, it will read crazy high meth content with some water contamination, and methanol tends to absorb water easily so in real life its highly possible.
There are many clips online where ethanol content sensors are tested, water added, watch the results, scary stuff considering that servo pump fuel tanks are vented to atmosphere.
Wouldn't you love your flex tune to advance the timing while you got a bad batch of water contaminated E85 after running on 98? :)
We had that SAU E85 night a Sabdinnies last year, was a real eye opener, add a bit of 98 to E85 and watch the E85 content drop dramatically, add just a little water to E60 and watch it become E100......scary shit.
They designed it to be scary shit Peter. Don't believe the hype. I do agree that the sensor is easily tricked, but water just doesn't get absorbed like that unless you leave the tank cap off in the rain.
Daz dropped his GTR off here for fabrication after his 2630 was built, we drained the tank as it had been sitting in Barry's workshop for a year and a half with no engine, open fuel lines and rail. After cleaning the injectors and lines he didn't want to run the old fuel, so I drained it and put in in my evo.
Thanks for the free fuel Darren, it ran fine at 32 pounds. AFR's were perfect, no det obviously. :P
  • Like 2
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
