Hey Guy's
I am one of the lucky few that has a dash in my R32 GTR with no bubbles/lifting and I want to do as much as possible to keep it that way.
I have had a protectomat dash mat made up by Vechicle Protection Co in CastleHill (www.vipco.com.au)
Very happy with the quality and fit. Its of a very good quality velour and stitch. Other colours are available.
It cost me $85 delivered to regional nsw.
If your interested contact phil at [email protected]. He is very helpful and turned around the mat in a few days. Mention jason from SAU and im sure he will look after you. They should also have mats for the R33/R34
Here are some quick pics. I have yet to fit the velcro/adhesive pads. I reckon it looks great and compliments the interior
Cheers
Jase
  • Like 1
https://www.sau.com.au/forums/topic/457089-r32-dash-mat/
Looks great! would be keen on one. wonder if we could get a group buy up
they sure do. i personally dont have the time to organise a group buy but im happy to ask phil if there is a bulk discount.
in my opinion given the quality and fitment they are worth the $70. Thats cheaper then replacing a dash. I doubt there is much margin in such an item to discount but we can ask
https://www.sau.com.au/forums/topic/457089-r32-dash-mat/#findComment-7543351
What holds it up/on ?
Seen the damage the Velcro tabs (glue) can do from dash pads. Hence my question.
That one seems to fit better than some I have seen
At the moment nothing. It is so well fitted to the design of the dash it needs nothing to hold it.
I have also done a drive up macquarie pass last week and the mat didnt budge
an adhesive velcro stripped is supplied and i will fit in places where the mat sits up a little.
Before purchasing I did enquire about what damage the adhesive can do. Phil confirmed it cleans up easy with Metho
Jase
https://www.sau.com.au/forums/topic/457089-r32-dash-mat/#findComment-7543352
  • 1 month later...
  • 1 month later...
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
