1.) Genuine Impul 33R Front and rear seats, ashtray with plaque, Gearknob. $1600
All in immaculate condition, Need a bit of a clean but no wear what so ever
2.) Genuine FULL 13 piece impul body kit. Front bar with inserts, Side skirts, Rear bumper, Rear bumper pod extensions, Rear overfenders, Tail light covers, rear spoiler. Front bumper had a crack which has been professionally repaired. Everything is in good condition ready for paint.
$1400
3.) Impul 701 3 piece wheels 17x9+25 include all centre caps. Fronts are face 1 for big brake clearance and rears are face 2 for dish.
$1400
Have better pictures and more information on each item. Please message if interested.
Agreed, great seats. Actually selling all this on behalf of a friend.
Its also very rare to find these with the embroidery intact. From my experience,the few i have seen it is always gone.
I should also mention he has a fair bit of stuff from this car so if theres anything required feel free to ask.
i assume those seats and rails will fit a 32 gtr??
i actually miss those seats, post them up in the stagea section, that trim matches the stag interior trim, i actually think there stagea impul seats.
Similar material to the suede mesh on stagea/ r33 gtr yep.
The rails will suit ALL r32-r34 except for ER34, a31,c33. They are very close to s13-15 with only one bolt hole needing modification
  • 3 weeks later...
  • 1 month later...
  • 4 years later...
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
