Hi Everyone,
I am currently looking at purchasing an EBC, but am unsure on which one is better. The two I have been looking at are the GFB GeForce II and the Turbosmart Eboost2. Both are relatively cheap, which is what I am after. But just wonder if anyone has one of these and has any advice/tips about either.
From my own research they seem to do the exact same thing, but the GFB one is fair bit cheaper, and I like how it will display the peak boost after for a short time
Also may be a stupid question, but i have a normal boost gauge on my A pillar at the moment, would the eboost be a simple swap in for it or would there be more wires/pipes needed? or will it even fit in the pillar?
Sorry for the noobish question, only still pretty new to forced induction.
Thanks in advance :)
I have used both that you mentioned and prefer the GFB unit. But it's a personal thing. Performance is identical
Both are awkward to mount in the cabin but the GFB has a nicer display so you can delete a boost gauge. Although the led lighting stands out if you get pulled over, it just might draw attention more than the eboost.
In conclusion: toss a coin
I used the gfb unit on my 180 and it was great, easy to use touch screen handled boost up to 50psi and very stable, could change colour to suit cabin gauges and the best thing is that it had an over boost function that cuts all boost at a pre set level so to prevent any spikes. Got mine for $300 a lot cheaper than others on the market, would defiantly buy again!
  • 4 years later...
The tuner I spoke to seems to think the eboost2 is better since you can set boost by rpm, so if you have a small turbo that’s dropping boost higher in the rev range you can set the boost higher as the revs climb.
He seems to the the GFB controller doesn’t have this function.
I see it it does have sensitivity, but apparently it’s not the same. Is that true and the eboost2 is better?
I do find with my Gforce it will peak at about 9 or 10psi then drop back to 7psi even though the target is 9psi but I think the turbo will run up to about 18psi
If I had to pick, I'll get the GFB as it's piss easy to use. Plus you can change the colour of the controller to suit your interior.
I've used an eBoost once and didn't find it very intuitive. At the end of the day, these things do the same thing with the same type of solenoid, yes the eBoost will allow you to boost by RPM however does your car/setup even need it?
So save your money, get the GFB and spend the change on your missus.
These days I would expect most ECUs do at least as good a job, have the ability to set other rules to decide how to manage boost control, and various inputs can be used if "on the fly" adjustments are needed - so really I'd not bother with any of them, or upgrade engine management and profit from having generally much better all kinds of stuff as a result.
I believe he is running a PowerFC - so running this on a near stock setup provides much better value for money.
Side note, the amount of people who splash out on EVC5/6 and don't bother connecting up vehicle speed and RPM input but yet insist on getting the best EBC because it controls boost well.
Oh yeah, for sure... for the OP that definitely makes sense - but given the original question was asked 4 years ago so I was talking more generally :)
Sorry was referring to Ben's more recent question about the EBCs which was asked on Thursday.
OP probably had Microtech with pots you adjusted with a flat head screw driver using visual cues to determine AFRs.
  • 3 weeks later...
Thanks all, will stick with the gforce 2 then.
Strange though, if I bring it on boost from say 2000 rpm in 4th I’ll get about 6psi from about 2000rpm, but it will stay there and slowly increase to about 8 or 9psi around 5000rpm.
Alternatively if I go full throttle in 1st gear I’ll get around 12.5psi around 5000rpm.
Its just strange that the boost isn’t that consistent? I would have thought with this small turbo, it should have been closer to the 12 psi mark from about 3k easy.
I’m thinking of trying out my old turbotech to see if that’s better?
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
