Hi Everyone,
I am currently looking at purchasing an EBC, but am unsure on which one is better. The two I have been looking at are the GFB GeForce II and the Turbosmart Eboost2. Both are relatively cheap, which is what I am after. But just wonder if anyone has one of these and has any advice/tips about either.
From my own research they seem to do the exact same thing, but the GFB one is fair bit cheaper, and I like how it will display the peak boost after for a short time
Also may be a stupid question, but i have a normal boost gauge on my A pillar at the moment, would the eboost be a simple swap in for it or would there be more wires/pipes needed? or will it even fit in the pillar?
Sorry for the noobish question, only still pretty new to forced induction.
Thanks in advance :)
I have used both that you mentioned and prefer the GFB unit. But it's a personal thing. Performance is identical
Both are awkward to mount in the cabin but the GFB has a nicer display so you can delete a boost gauge. Although the led lighting stands out if you get pulled over, it just might draw attention more than the eboost.
In conclusion: toss a coin
I used the gfb unit on my 180 and it was great, easy to use touch screen handled boost up to 50psi and very stable, could change colour to suit cabin gauges and the best thing is that it had an over boost function that cuts all boost at a pre set level so to prevent any spikes. Got mine for $300 a lot cheaper than others on the market, would defiantly buy again!
  • 4 years later...
The tuner I spoke to seems to think the eboost2 is better since you can set boost by rpm, so if you have a small turbo that’s dropping boost higher in the rev range you can set the boost higher as the revs climb.
He seems to the the GFB controller doesn’t have this function.
I see it it does have sensitivity, but apparently it’s not the same. Is that true and the eboost2 is better?
I do find with my Gforce it will peak at about 9 or 10psi then drop back to 7psi even though the target is 9psi but I think the turbo will run up to about 18psi
If I had to pick, I'll get the GFB as it's piss easy to use. Plus you can change the colour of the controller to suit your interior.
I've used an eBoost once and didn't find it very intuitive. At the end of the day, these things do the same thing with the same type of solenoid, yes the eBoost will allow you to boost by RPM however does your car/setup even need it?
So save your money, get the GFB and spend the change on your missus.
These days I would expect most ECUs do at least as good a job, have the ability to set other rules to decide how to manage boost control, and various inputs can be used if "on the fly" adjustments are needed - so really I'd not bother with any of them, or upgrade engine management and profit from having generally much better all kinds of stuff as a result.
I believe he is running a PowerFC - so running this on a near stock setup provides much better value for money.
Side note, the amount of people who splash out on EVC5/6 and don't bother connecting up vehicle speed and RPM input but yet insist on getting the best EBC because it controls boost well.
Oh yeah, for sure... for the OP that definitely makes sense - but given the original question was asked 4 years ago so I was talking more generally :)
Sorry was referring to Ben's more recent question about the EBCs which was asked on Thursday.
OP probably had Microtech with pots you adjusted with a flat head screw driver using visual cues to determine AFRs.
  • 3 weeks later...
Thanks all, will stick with the gforce 2 then.
Strange though, if I bring it on boost from say 2000 rpm in 4th I’ll get about 6psi from about 2000rpm, but it will stay there and slowly increase to about 8 or 9psi around 5000rpm.
Alternatively if I go full throttle in 1st gear I’ll get around 12.5psi around 5000rpm.
Its just strange that the boost isn’t that consistent? I would have thought with this small turbo, it should have been closer to the 12 psi mark from about 3k easy.
I’m thinking of trying out my old turbotech to see if that’s better?
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
