Hi Everyone,
I am currently looking at purchasing an EBC, but am unsure on which one is better. The two I have been looking at are the GFB GeForce II and the Turbosmart Eboost2. Both are relatively cheap, which is what I am after. But just wonder if anyone has one of these and has any advice/tips about either.
From my own research they seem to do the exact same thing, but the GFB one is fair bit cheaper, and I like how it will display the peak boost after for a short time
Also may be a stupid question, but i have a normal boost gauge on my A pillar at the moment, would the eboost be a simple swap in for it or would there be more wires/pipes needed? or will it even fit in the pillar?
Sorry for the noobish question, only still pretty new to forced induction.
Thanks in advance :)
I have used both that you mentioned and prefer the GFB unit. But it's a personal thing. Performance is identical
Both are awkward to mount in the cabin but the GFB has a nicer display so you can delete a boost gauge. Although the led lighting stands out if you get pulled over, it just might draw attention more than the eboost.
In conclusion: toss a coin
I used the gfb unit on my 180 and it was great, easy to use touch screen handled boost up to 50psi and very stable, could change colour to suit cabin gauges and the best thing is that it had an over boost function that cuts all boost at a pre set level so to prevent any spikes. Got mine for $300 a lot cheaper than others on the market, would defiantly buy again!
  • 4 years later...
The tuner I spoke to seems to think the eboost2 is better since you can set boost by rpm, so if you have a small turbo that’s dropping boost higher in the rev range you can set the boost higher as the revs climb.
He seems to the the GFB controller doesn’t have this function.
I see it it does have sensitivity, but apparently it’s not the same. Is that true and the eboost2 is better?
I do find with my Gforce it will peak at about 9 or 10psi then drop back to 7psi even though the target is 9psi but I think the turbo will run up to about 18psi
If I had to pick, I'll get the GFB as it's piss easy to use. Plus you can change the colour of the controller to suit your interior.
I've used an eBoost once and didn't find it very intuitive. At the end of the day, these things do the same thing with the same type of solenoid, yes the eBoost will allow you to boost by RPM however does your car/setup even need it?
So save your money, get the GFB and spend the change on your missus.
These days I would expect most ECUs do at least as good a job, have the ability to set other rules to decide how to manage boost control, and various inputs can be used if "on the fly" adjustments are needed - so really I'd not bother with any of them, or upgrade engine management and profit from having generally much better all kinds of stuff as a result.
I believe he is running a PowerFC - so running this on a near stock setup provides much better value for money.
Side note, the amount of people who splash out on EVC5/6 and don't bother connecting up vehicle speed and RPM input but yet insist on getting the best EBC because it controls boost well.
Oh yeah, for sure... for the OP that definitely makes sense - but given the original question was asked 4 years ago so I was talking more generally :)
Sorry was referring to Ben's more recent question about the EBCs which was asked on Thursday.
OP probably had Microtech with pots you adjusted with a flat head screw driver using visual cues to determine AFRs.
  • 3 weeks later...
Thanks all, will stick with the gforce 2 then.
Strange though, if I bring it on boost from say 2000 rpm in 4th I’ll get about 6psi from about 2000rpm, but it will stay there and slowly increase to about 8 or 9psi around 5000rpm.
Alternatively if I go full throttle in 1st gear I’ll get around 12.5psi around 5000rpm.
Its just strange that the boost isn’t that consistent? I would have thought with this small turbo, it should have been closer to the 12 psi mark from about 3k easy.
I’m thinking of trying out my old turbotech to see if that’s better?
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
