Got the RB30 engine on the stand, noticed the bore has developed a golden tinge to it, so very light beginning of rust? I've oiled the bore and turned motor by hand, but obviously as the piston goes down it cleans the bore. I've squirted some lanolin on the bores and turnt by hand again...
Should I worry about this or will the lanolin remain on the bore?
https://www.sau.com.au/forums/topic/457146-rust-prevention-while-engine-apart/
I've seen my boss glad wrap his block 360 degrees and use oily rags on his drag car.
Makes sense to me glad wrap to stop morning dew or humidity.
Oily rag to oil it.
Lanolin would be a smarter choice then fish oil. Fish oil gets very sticky.
I would not worry about it 1st fire will smell like sheep :D
Edited by pol1on1
I always used to drown everything in ATF, then wrap them up in an oil soaked bedsheet. Then bag it for good measure.
Kept a mates built 308 bottom end shiny and lovely whilst his B-port heads were rebuilt by the slowest head shop in the world.
Light oil on the piston tops and crank it over then light grease applied to the exposed bore in a similar way you might grease a baking pan and cover the top of the bores with a plastic sheet over the top of something like cotton T Shirts sprayed with WD-40 or similar water dispersant.
Big Plastic bag over the lot like Dale
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
    • Nistune needs something like an entire excel spreadsheet in which you build an abstraction layer that converts everything from real units you can actually measure into all of the various tables. The number of unexpected dependencies hiding in how the Nissan ECUs do math is a pretty impressive optimization trick for 8-bit MCUs but good god is it awful to actually work with in practice.
