So atm the lettering on the back of my R32 looks like this:
Is the panel removable to clean/restore inside the lettering? If so, how does it come off? I've tried pulling at it gently to remove it and it's stuck pretty good, but it looks like it's removable. If I can get it off, what's likely to be causing the moisture buildup? It's been there since I bought the car in January and I've only just now gotten the time to do something about it.
Cheers.
I have the same problem with mine as well, visible moisture and mine does not even light up at nigh.
I tried removing the unit off the rear bumper but the center part is stuck on there really well with what looks like double sided tape. I can get the side free but the darn center is stuck on really well. Anyone have any advice on removing the center part?
I didn't even realise that it was supposed to light up! I just learned that yesterday from a guy at a meet, so now I'm even more inclined to get it working again. From what I've been told, it's a factory optional and it should light up in blue, red, or green, depending on what the original owner got it with. Glad I'm not the only one with the moisture problem though.
I'd suggest getting it hot with a heat gun and getting some fishing line behind it
That sounds like the way to go, cheers mate.
No worries :)
As for the back light, my friend has an R32 with the same light, and not surprisingly, it doesn't light up and has the same moisture issue :/
EDIT: forgot to mention after getting the light up panel off, clean up the gluey residue with a caramel wheel :)
Edited by Jordy32
No worries :)
Aye, 20+ year old lights though, it's not surprising that they don't work. I'm going to attempt to take it off, clean it, wire it with red lights that act like the brake lights and seal it up when I put it back on to stop the moisture getting back in. Shouldn't be too hard, I think.
    • At least you're now aware of the problem and can come up with a solution.
    • Dang. Keen for further updates when you get to it.
    • Welcome to SAU Thomas, sounds like you'd had a bit of a an unlucky start with the car, hopefully you get some better luck now!
    • 1. No need, it only gets used once then is locked in place by the nut 2. EN-62 point 6 shows the conical washer the other way around (BTW I know we discussed above, I hope you are changing the idler as well, while it is no guarantee the bearing is a actually bad, it looks terrible) 3. I'm not really clear on the question, are you worried because it was easy, not hard, to remove the custom timing trigger? As long as it doesn't spin on the crank (when the bolt is tight) all good 4. Yeah just make sure the brand is easy to read as it rolls past 5. The part number is on the listing under the description, 13023-42L00. Given there is a custom part on there for timing (presumably outside the cover), they may have decided to leave that off; I think I would put the washer in there as it also helps seal the timing case from crap getting in.
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
