Pauter titanium x beams. At around 9k for a set landed and sized that's got the rods covered. As for Pistons, you can custom order Pistons from the mclaren Mercedes engine division at around 25k, however the tolerances required to run these mean you must preheat all fluids and componentry before starting. However, at 400kw with "room to grow" you aren't giving enough information. For a basic build, do what the other 40 thousand rb owners have done, cp and a good h or I beam from Manley, spool, God, I dunno, look.
  • Like 2
Not sure if true, but ive heard that valve springs can be damaged if motor is flogged cold? I cant imagine a mechanic in Japan working for Mines, to say no no no, don't use tomei, use only supertech!! lol... just saying... :ph34r:
Read it on Oztrack.com.au , there's other causes like bouncing off the limiter, overheating etc..
there was a thread only about a month ago where someone else had exactly the same issue and fixed it by fitting non Japanese branded valve springs, really it's up to you, you can listen to people who have real world experience with their own cars, or you can listen to brand fan boys who's experience is something they once read that someone posted about their neighbors cousins sisters boyfriends friends car
At the end of the day it's your money and your car and what you do with them is your choice, but it's not always the poor man that pays twice, some times the ignorant man does as well
  • Like 1
I run tomei springs and valve guides etc etc.
Reason.
Guy ran same head work for 100,000km's before the rod snapped (same story blah blah). Seen the rod. What a mess.
The guy that built the engine is Japanese and did say with the jap kit it requires knowledge on how to assemble them.
Anyway - im sure there is some good kit in aussie. Would be tempted for nitto stocker one day :)
The tomei springs will work as long as the valve seats have not been cut, the issue is that these engine are now old enough, that if you don't cut the seat you end up with leaking valves.
Of corse there is some good stuff here, Japan asked us not to bring our group A cars over there 25 years ago, so we've always been a head of the game
haha.. you must be joking, ahead of the game? so are you saying Australian cars are ahead of the game on the japs, I don't think the 35GTR is behind any game anywhere...
Edited by AngryRB
Oh dear. He was referring to the Gibson Motorsport Group A R32's which were massively ahead of their Japanese counterparts in the Group A era and also to the high levels of competence and knowledge base in our local motorsport. He was not talking about the manufacture of road cars.
  • Like 2
this^^
You're right I did edit the post but the only thing I changed was the 1 to a 2 because I hit the wrong key, the rest is exactly how I posted it in the first place
Most people would have reconized it was supposed to be 25 due to group A no longer existing after 92
    • My purchase experience was no where near as glorious as yours but still a significant moment in my life! Yeah that's a bit of a dilemma as to whether you bring it back or not!  Obviously a massive waste of time and effort to bring it back if you're only going to move there anyway!
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
