VB cans work, bed in easily. I tried Four XXXX but got all crossed up and ended up in the pissed n' broke/piston broke club!!!!
Real answer - It depends on your power goals vs your budget. Standard takes more of a hammering than we all thought they would. Then theres plenty of aftermarket and none have a bad reputation, as somebody said its not the product its the build you get that is the defining limit.
Sort of good point. The reason I went with Tomei pistons is because I talked to someone that put 100k (over 10years) on an engine with them - had some track work too.
He had standard rods with tomei bolts. Rod ended up giving up.
So when i looked into them they seemed like the best option for a RB26. So far 12,000km on with them. Hopefully another 80+ to go.
I reckon anything Jap, 9 times out of 10 would have to be the best or close to it, they usually make/build as we know, great engines , so makes sense they will deliver an outstanding piston ( Tomei ) to put in there own designed/built engines.. :ph34r:
Edited by AngryRB
INB4 piggaz gets here and starts talking about jap cams and valve springs.
Edited by iruvyouskyrine
Here is a story.
Once upon a time.....
There is a bloke in Victoria from Pacific Engine Parts who supplied the piston rings Fred Gibson used for the Group A GTR's. Knows a thing or two he does. If you want a good piston get good rings and built the motor properly. We do good engineering in Australia too, you know. Or atleast did before the Chinese, the mining boom and the wrong headed notion that if it is from overseas it must be better destroyed all our manufacturing industries.
Oi how shit are those jap springs and cams!
Seriously though, they re shit
I'm not disagreeing haha, I just know he won't stand for someone saying how good tomei type b poncams are and the quality of Japanese valve springs. Really gets his goat :P
He isn't the only one with the same story, but basically it goes along the lines of fitted Japanese valve springs (tomei in mine, hks in his) neither had enough seat pressure and caused miss fires in his due to float, mine were checked before being fitted, both replaced with super tech and now fine
The real answer is..if you have to ask on a forum, you probally don;t need them...maybe a bit harsh..but true
cheers
darren
So researching and checking ask your facts before pulling the trigger means you don't need them?
Guess all the cheque book racers who get 1000hp plus built lambos and the likes don't actual need after market pistons in that case?
Such a stupid logic some people have, not like I asked do I need after market pistons for 300+kw or something.
one of my tomei springs broke and wrecked my engine :(
Further make this a discussion about valve trains*
Not sure if true, but ive heard that valve springs can be damaged if motor is flogged cold? I cant imagine a mechanic in Japan working for Mines, to say no no no, don't use tomei, use only supertech!! lol... just saying... :ph34r:
Read it on Oztrack.com.au , there's other causes like bouncing off the limiter, overheating etc..
Edited by AngryRB
Pretty much..
I assume that you want way over 1000hp at the crank....to even ask the question..so my assumption is that you don't need them if you have to ask...
Ill put it to you that unless you done over 1000hp at the crank ..before ...that you will run into the same sort of probs that workshops that have done this have encountered..and that
you stockpile blocks and practice nuking cheaper parts first because the rods and pistons , even cheap chinese shit wont be your problem...
if your a chequebook racer, well just go sign the cheques, if you need to double check said workshops info , you need to find another workshop
sorry if i offend you
cheers
darren
Pretty much..
cheers
darren
Nope aiming for 400kw with a little room to grow. Why not upgrade pistons if the block will be stripped in the build anyway?
Get my reason?
And no not offended just find sometimes people are rude on this forum to legitimate threads or questions for no reason and it doesn't help the community grow.
Not saying yours was but it could be perceived like that
Edited by anon32
Well just some random thoughts on general SAU stuff.
Try and avoid F&F/Facebook language. Whatever the merits (or otherwise) of such language a considered, well put together post to start a thread will get a much better response than something that sounds like it was written by a bored, trolling teenager in 30 seconds. (Not saying yours was quite that bad.)
If you had have asked for a piston recommendation for a 400kW build you would have got no end of people saying Tomei/CP/JE/Nitto etc etc. All of which are fine.
If you had have asked what attributes of a piston may be important on an RB you may have got a different answer again.
TL:DR. When you start a thread try not to sound like a teenager, try and make it sound considered, include what you know and understand that aside from just answering (or not) your question it may well provide information for someone else at another time.
Lastly if you think I should shove my post up my ar$e that is probably fair enough.
  • Like 2
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
