Hello guys
I am more after pictures here, I bought a Mamba GTX3076 turbo kit, which came with a universal Oil and Water line kit, I can see that I will need to replace the oil feed fitting in the block to adapt to AN fitting (-4 I think) but I didn't get it in the kit, anyone know where I can get one from in Adelaide?
Also, anyone show what they have done with their water lines, I got solid ones which are about 20cm long, with barbed engine fitting, I cannot see how they can join into any where.
I would be after peoples pics with Kinugawa kits if possible, as they are similar.
Cheers
Edited by boothy_99
Um, just about any hydraulic bits supplier. Enzed and Pirtek, Shipways, probably a bajillion others. Outlaw speed shop, OG speed shop etc etc (depending on who's still n business - I haven't looked lately!). Just about any of the turbo workshops (Turbo Tune, MTQ, etc). This is just off the top of my head.
All you need to know is the thread you want on the other end.
If you follow the water line, it mates to a rubber hose behind the head.. it's a slart to get to, but you'll manage... if your hands are too big, you can loosen the gearbox mount & tailshaft bracket and jack up the gearbox - this gives you another 1cm of clearance (that's what I did to get to it)... I think on the R34 NEO motors however it's a metal line all round. On the R33 RB25 and R32 RB20DET it's a stupid rubber hoses with a spring clip.
can someone tell me quickly what that rubber hose goes to on the intake side? my engine came without a turbo on it and ive since deleted all the heater hoses and behind the head hoses. trying to work out whats the best place to source coolant from now...
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
