Hey guys,
Recently finished my build and have only clocked about 1,000kms on the new motor.
Having a small issue which has had me baffled for a few weeks now.
My oil pressure light stays on when I start the car and is very lazy to build pressure. I think (on a cold morning) it takes upto 2 seconds for oil pressure to build up. I can also confirm that I hear the hydraulic lifters tapping loudly until the light turns off.
Once the car is on, my oil pressure is fine. Starts off nice and high and reduces to a good level as the oil warms up.
So to clarify, I have absolutely no oil pressure issues once the car is on and I'm driving.
I've tried researching a lot and can't find any decent leads - I'd greatly appreciate if you guys could provide me with some advice on how to resolve this issue!
I'm desperate for help as I'm leaning towards buying an oil accumulator to resolve this issue - i just don't want to blanket cover a deeper problem.
Cheers guys!
https://www.sau.com.au/forums/topic/457179-rb3025-start-up-oil-pressure-issues/
what oil you using?
what mods done to engine?
any oil cooler or additional things in oiling system?
what guage?
Oil: royal purple 10w:40
Mods to engine: 40 thou forged Pistons and rods, crank with extended crank collar, n1 oil pump with standard gears, standard oil sump + pickup, cancelled VCT and grub screwed the feed.
Additions to oil system: none at the moment - only thing I did was fit the stock rb25 oil cooler thing to the rb30. Not using an aftermarket oil pressure gauge... Using the shitty stock one at the moment.
I know the stock gauge is inaccurate, but I know the light is accurate because once it turns off, the tappet noises quieten down.
Your oil and filter choice is fine. But the pressure not building up instantly on start up is a problem. You shouldn't be seeing a delay in pressure build up and the light should not come on.
There is definitely some underlying problem and the tappet noise could well be related to it.
Is there anything you may have skimmed over in the build (if you did it yourself) accidentally or some kind of blockage/restriction?
Might want to check the oil cooler is not getting restricted, causing that slight delay in pressure build up.
what is the hot oil pressure reading? your not going to know this with OEM shitty gauge... get yourself an aftermarket one and sus it out. If over all pressure is low or it drops when hot then i'd dare say your bearing clearances are up shit creek
I built it myself with a mechanic over watching what I did. I don't recall missing anything and I'm not having any blowby issues.
Need an aftermarket gauge to tell you the exact pressure, but my oem gauge has similar readings to what I used to have before the rebuild. It seems as though issue is solely on startup but I do plan on getting a mechanical gauge thrown in to test...
Filter drainback valve thingo.
I already tested for that issue. I turned the car off and let it sit for a day and then unscrewed my oil filter and it was still full of oil. Unfortunately that's not my issue :(
The grub screwed vct oil feed- would this have an affect?
Research has shown me that everybody does this so I didn't even think about it. The grub screw is in the head though, so would it effect oil pressure at the sender unit in the block?
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
