Hey guys, I've got an 96 R33 S2 with an RB25DE NEO in it.
The problem I have is it is running super rich, just above my exhaust on my bumper is black like solid black & I'm getting shit fuel economy. When I drive I can just smell fuel & the same when standing outside the car. I know Skylines aren't cars for fuel economy but it's N/A and I'm getting roughly 320kms to a tank. A mate of mine has a 96 S2 R33 GTS-T and he said he gets 350-400kms flogging it! I know it has a lot to do with the driver & the way I'm driving but I don't believe I give it to it a lot, of course every now & then, I change gears around 3k RPM.. For modifications I only have an X-force rear muffler, pod filter & super spark coil packs. I've just had the correct harness & ECU installed as it was running a GTST computer & R33 harness with the plugs replaced to suit the NEO from the old engine, performance wise it's so much better but fuel economy stays the same?
Sorry if I'm a bit oblivious guys bare with me, I'm a newbie to Skylines. Always been a fan it's just my first time owning one.
Any help on suggestions to diagnose the problem or things that may help improve it are appreciated!
Cheers,
Jordan.
https://www.sau.com.au/forums/topic/457257-help-rb25de-neo-running-rich/
Possibly the O2 sensor needs replacing or maybe the thermostat. Does the car take a while to warm up?
Another thing that could be is the water temp sensor for the ECU, if it's giving a wrong reading (too cold), the car will think that it's still needs to warm up and will keep running rich to try and do so.
I find revving out the engine a bit more (3k) when cruising to be better for fuel economy as long its kept at light load to keep momentum.
What ECU are you now running?
  • 3 weeks later...
Hi guys thanks for the reply!
@ErOR my car does take a while to warm up now you mention it, about 10-12minutes if it's just on idle, also I pulled out my O2 sensor to clean it & it was black!! Big carbon build up I guess, that was about 4 months ago I cleaned it with sandpaper to get all the carbon off.
@scotty nm35, how do i check if I have turbo injectors? I have the part number with me, I have searched them up but I can't seem to be finding much.
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
    • I've never done dial in's just straight up, whatever that's called. I'm far from a drag (racing ) expert.
