Hi guys I've been having some problems with my gtr I have a hks t04z on a stock rb26.
The turbo makes boost (18psi) but there's no punch from the car anymore. When I first did the conversion it was super fast an put u back into your seat but lately it doesn't put u into your seat at all.
The boost gauge an greddy boost controller both say that 18psi of boost is made when driving but the car just does nothing.
I've checked all over for boost leak/vacuum loss all ok
I've replaced the clutch with a new twin plate.
Engine has 175-180 psi of compression
Wastegate seems to be working it's not stuck an vac lines R ok
The turbo has some play in the compressor shaft has some forward an backwards movement 1-2mm max an has some up an down too.
It does blow some white smoke from time to time.
Can anyone please help with a possible test or check I can do it sort the problem out I've done about all I can think of.
Thanks
Guys
https://www.sau.com.au/forums/topic/457277-r32-gtr-hks-t04z-power-loss/
Yeah I have a haltech platinum pro with the wideband O2 kit.
I'm taking vac readings from the fuel reg port, stock boost gauge port an where the stock boost solenoid went.
An it's down on power to the point a stock v5 golf gti can pull away from me
( mine had 450hp 3 months ago )
    • That would be interested if it's the case as seems like it would make the job a lot messier but subaru sells OEM gaskets so seems it might of had it.
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
    • I will get a couple cans for sure thanks, I do have 2lt fish oil to spray around the car already.
    • Thought I’d post pics of the packages for those interested. The premium package is #16. Remote start, security with tilt sensor and remote and backup battery, auto fold mirrors and door illumination.    Can post up pics of all the factory options and images from the factory options brochure if people are interested. I have all the dealer books etc for all rv37 models.
