Hi All,
I'm looking to let go of a few cars that my family owns.
This is our 2007/08 Nissan Skyline Sedan V36 SP - Driven by my father (very rarely does anyone else drive it as we all have our separate cars).
79xxx Km's
Rego'd (I'll double check later on when I'm back home on time remaining on the current rego but from memory its 5+ months)
Includes leather seats and sunroof (which is a rare option)
Screen + Reverse and side camera's
Log books and Japanese paperwork included
All other options as in standard V36's
Pics aren't the best because I'm slightly novice at taking nice pictures - car is much better looking and super clean
I'm asking for $21000 or best offer
Please contact me via PM or SMS/Call me on 0415 605 565 if you have any questions or want to have a look etc.
Thanks,
Edward.
Edited by Ezy03
  • Like 1
Hi All,
79xxx Km's
Thanks,
Edward.
Looks great, at $21k you're right on the money Edi, even for a 350GT :yes:
Diamond Silver > Pearl White > Lunar Grey > Black
Beige Half Leather > Beige Leather > Charcoal Half Leather > Brown Leather > Charcoal Leather > Red Leather
Your leather interior is not rare (but it's also not common) - it is however part of the Premium package which was a factory option (and highly sought after) and is part of your Type SP.
Your sunroof and rear spoiler on the other hand *are* rare and the right buyer will pay a premium for these options (which I personally do like) - don't forget your car also has cruise control (which is also rare).
You also forget to mention your car has CarWings DVD Navigation (and possibly the Music Box) + it has bluetooth music streaming :D
Edited by Sikahalv
Thanks for the props George, I think the interior is the brown although I must say I haven't seen either the beige or brown in anyone else's car. However, I can say that it is more a darker colour, I'd sway more to say it was brown than beige.
Also I do want to confirm it is a 350GT
Greg, I do have it listed at $21k and I am negotiable - I think 370GT's are higher in price (around 26k mark - this was the last time I checked.
You might be right.. I was just looking at the cost to import one which seems to be quite a bit cheaper than buying locally. Probably to the right buyer the sunroof/cruise/etc are a big ticket item.
these are some of the examples I have been looking at.
http://prestigemotorsport.com.au/stock/show_car.php?id=2891
http://prestigemotorsport.com.au/stock/show_car.php?id=3022
http://prestigemotorsport.com.au/stock/show_car.php?id=3254
  • 3 months later...
  • 3 weeks later...
Brand new Hankook K117's all round!
Rego is until next Sept too!
$21k ONO :D
I will throw in full detail and full tank of petrol for the buyer too!
Edited by Ezy03
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
