Hi,
my blitz base is on the manifold intake as replacement for the original dump valve and the port at the back of it to the vacume.
today i noticed the dump valve is sucking air in as if the blitz is sucking air in from the dump valve port
Also i have no base washer would that matter that much ?
base to inlet manifold.
many thanks
Dump valve is sucking air in on idle
Now i know the dump valve is connected from its base to the inlet manifold which provides the positive pressure feedback
You also have a port/ nozzle or whatever you want to call it at top of the dump valve which is connected to the vacum
I think that port sucks the diaphgram in pulling piston up and letting air out when needed
Now the issue is if you hold your hand or even a tissue paper on the venture of the dump valve it is vacumming and sucking air in
Makes sense?
I'm guessing you're not a native English speaker. Perhaps you need a photo with some arrows pointing out the features you are talking about.
For one thing.....dump valve is not a normal term. We will assume you're talking about the BOV, which is still not even the right term on a Skyline, because in truth, what it really is is a compressor bypass valve.
Because it is a compressor bypass valve, it is actually intended to be connected back to the compressor inlet. The vast majority of stupidity associated with Skylines revolves around venting BOVs. Leaving them open to the air requires that do you a few other mods, most of which don;t get done by most people who like venting BOVs. Hence the stupidity.
Anyway.....please do what I said in the first paragraph.
@GTSBoy
Many thanks for the explanation . Yes I am referring to the BOV or in here is it referred to as dump valve .
I have installed the blitz which is a direct replacement for the manufacture bov.
If you look at the pic below.
1. Area highlighted in red is connected to the base of the inlet which is connnected to the inlet manifold pipe . It has no paper washer between the too metals but it doesn't seem to leak .
2.Area highlighted in black is connected to the vacume ( negative pressure) which I think opens the diaphragm and pulls the bov piston up to let the excessive pressure out.
3. the area highlighted in green is where I am getting vacume on, at idle and across rev range until the bov opens and vents the excess of air in which case it then blocks rather than suck air in .
I know with AFM you are not meant to have BOV as it can run rich between gears but I am ok with that rather my issue is why is it sucking air in .
Is the diaphragm gone so the vacume is sucking air in ?
Edited by stranger12
well I did and as you said it only opens on high pressure ( high rpm range).
I want it to come on from 2k .
I did adjust the screw in all the way and still it was sucking air in , maybe it is by design but I guess that messes the air.fuell ratio as you are getting extra air from the inlet port?
I am currently having misfire and trying to find the cause and this being one of it
If you have no gasket for the bov then I can guarantee it will leak boost above 4-5psi. I tested it even after cleaning the surfaces
Stock bovs leak vacuum too but the air that leaks in has been measured by the air flow meter so it doesn't upset anything.
I hate to say it but unless you go mafless on a different ecu then you're 100% better off going back to the stock bov with an oem metal gasket
Edited by Blackkers
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
