Hey guys,
My trusty Hiflow turbo is up for sale! I've moved onto bigger and better things (Went for a biiigggerrr Hypergear) and this spritely little bugger is up for sale!
Will bolt on straight into where your stock turbo is, but it will make some decent power.
Usual Hypergear specs. Did 240kw on Pump 98 with a return flow cooler, exhaust and a Nistune.
No unusual shaft play. Turbo is working good and will be off my car in the next day or so.
Located in Eltham Vic, can meet up.
Looking at $550
Don't have pics. Looks like a stock turbo basically.
Injectors were changed, but I was running stock injectors at like 105% duty cycle before hand on the same boost.
Since then i've changed fuel pump as well.
Sorry I forgot Z32 was installed.
Looks like it's sold though.
Please make sure that braided oil line is used with this turbo. No oil restrictors should be used. All fittings that is connected to the oil line should have a inner diameter of at least 3mms.
  • 3 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
