Hi Guys,
I fitted eccentric bushing caster arms into my R33 recently and thought I would do a very quick write up on it (my first write up so take it easy!)
Tools needed:
- 17mm socket and accompanying ratchet
- 17mm spanner
- Pry bar to move the suspension/wheel forward to accommodate for the change in suspension
- Soft mallet to make things easier if things are stiff
- Jack
- Jack stands
Time needed: 30 minutes max for a first timer includes finding the right tools, jacking up and packing everything away.
Info: An eccentric bushing or bushing with eccentric crush tube is one which offsets the position of the bushing for adjustment - In this case, caster.
Before VS After:
6D298CB9-926D-4029-9D30-A1577DF4E37A_zps
7DA8F4FB-7191-43C4-BE47-3AFED56B2F1E_zps
1) Jack the car up and place stands under it. Place the stands in a place which will allow you to get under the front wheels safely an with ease
2) Undo the 17mm bolt using two spanners or a ratchet and spanner on each side from the front busing
3) Undo the two 17mm bolts off the studs on the lower control arm
2870B16C-D014-408C-AE1D-F4AD77E7DFFF_zps
904B8E77-8808-4B18-B480-B0CC6DCF7226_zps
4) Push the caster arm up and out of the way
Installation is reverse of removal however depending on how your eccentric bushing is set you will need to move the wheel forward or backwards to get the holes to align. I put my eccentric crush tube in the position that shortens the length of the caster arm. This meant that I had to push the back of the wheel to the front of the car.
I also have a video of the old bushings in the stock caster arms which is still uploading but I'll post here when it's done.
Let me know if there any improvements for next time!
Cheers
https://www.sau.com.au/forums/topic/457326-diy-r33-eccentricoffset-caster-arms/
  • 3 months later...
Just an update on this
I got stung pretty badly by the alignment shop because of these bushes. They said it took ages to adjust therefore cost more because they kept having to remove and reinstall.
This confirms my theory that eccentric bushes are good in theory but less so in practice. I used to run Whiteline eccentrics in the rear (spent ages pressing out the OEM bushes too) and ended up replacing camber and traction arms with adjustable items, much easier to align.
  • 3 weeks later...
Yep - The alignment shop wasn't very impressed nor was I when it came to paying the bill.
He said "The price difference between the two is good but when the arms have to come off this many times you start to pay a lot more for labour so it works out the same anyway"
  • Like 1
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
