I'm scarred.
The car does have a little damage where somebody has tried to jimmy the door open. Also the front bar is a little damaged to (someone tried to remove it)
The car does have a little bit of white smoke coming out the exhaust however after a few revs it went away and didnt come back.
Anyway the price is such that I could afford to fix the door and a turbo even 2 if need be a still be doing ok.
Apart from that I checked the car thoroughly and it looks good.
* Checked the radiator for white deposits near the cap - none.
* No rust in the boot.
* No unusual sounds from drivetrain, gbox or engine.
* No perceivable leaks engine or otherwise
* Interior clean.
* Rest of panels straight.
* Engine sounded good and normal.
* 70k on clock (who really knows)
* 95 model
* 400r side skirts, front bar and bonnet (might be fake i wouldnt know)
* supplied with safety certificate and rego
* aftermarket exhaust looks to be only cat back
* pods (m's?)
* Enkei wheels 17in i think.
Fingers crossed i get it and it turns out ok. Either way I will let u guys know.
I'm an impulsive idiot but I did have a dam good look at everything I know a bit
about mechanicals etc - and I know people etc.
https://www.sau.com.au/forums/topic/45734-omg-i-just-put-a-deposit-on-a-r33gtr/
  • Replies 89
The two most important points you missed:
GET THE CAR UP ON A HOIST!!!!
Don't buy the vehicle the first time you see it. Go home and have a GOOD think about it. One more day isn't going to kill you, but it might stop you from making a bad impulse decision.
You should never have to tell yourself: "Fingers crossed i get it and it turns out ok" :D:P
I can't believe the engine was blowing smoke, and you didn't get a compresssion test done on it, and bought it anyway.... :uhh: :uhh:
Correction I havent bought it just put a deposit on it.
Lergo I have arranged for an onsite compression test
and pre purchase inspection this wednesday 12-2pm
for $150.
If I don't go through with the purchase I loose my $450
deposit plus the $150 comp test or $600.
Figure its worth taking the punt on for $600.
I feel better now.
The thought of owning a 33GTR is really freaking me out.
I need to settle. Then I need to think about alarms. That's
the thing that worries me the most its 2x the thief magnet
than my gtst.
Ok guys I need advice on engine/vin/chassis numbers.
It doesn't look right to me, I did find it hard to read
his writing. I will verify myself under the bonnet
and check the numbers with REVS before purchase
but here goes.
Engine : RB26047818A (seems ok)
VIN/Chassis: 6T91MPAAAR1BFH002
Thats doesnt look anything like my
gtst's number. I would have expected
a BNR33 or similar?
He's got writing like a doctor!
Mmmmm I am really starting to worry about this white smoke.
It occurred when the car was idling after being cold. Had it idling
for about 10mins.
The guy tried to convince me that all his cars did that after they
had been washed?
After reving a few times it did go away though?
The smoke was kind of blowing out and wafting vertically from
the tip it seemed very diffuse and light. Not blowing straight
out like I' ve seen other smoky zorsts do.
for about 10mins.
had been washed?
Im not sure whether to forget about it and save myself the $150.
I mean even with a pre inspectin check and compression test
the problem may not be identified, right.
This car is around $30k registered btw. Yes cheap for a 33R.
for about 10mins.
had been washed?
MMM.. im starting to get worried about the repeats... :D
Adding to the white smoke, may i ask... for such a stock car with stock wheels etc.. why does it have a fibreglass bonnet and what seems to be a fibreglass copy of the original front bar that is missing the orignal indicators and surround. Also a grill that looks like a copy with no GTR badge? Another thing to think about...
I wouldnt normally give my thoughts but think you should really consider some things i mentioned. :headspin:
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
