This car does not have stock wheels.
The grill has a GTR badge.
The front bar is not an original standard
front bar.
Just curious what color is the car you
are talking about.
Assumption is the mother of many mistakes.
Your reply is a bit smug please feel free
to PM me with any constuctive comments if
u know this car so I can avoid making a
mistake.
Richard
  • Replies 89
Are you sure the white smoke just wasn't steam coming from the cold exhaust in cold weather? Water condensation evaporates when the exhaust heats up and steam rises, that old trick? Maybe the guy wasn't talking out his ass because they would be more likely to do this when washed/rained on.
If it was "wafting vertically" and "diffuse and light" then it could be steam. Next time you start it from cold, watch the exhaust and "feel" the smoke. If it is steam it will condense on your hand and you will have a dirty wet palm.
I don't think it was steam. Although I didnt hold my hand above it to check (should have).
It did seem to go away though after a few decent revs... The engine reved out nicely. No strange sounds.
I'll let u guys know how the mech/comp test goes tommorrow. That and the REVS check are the last 2 hurdles the owner has accepted my offer.
I will loose the $600 from deposit and mech check but figure thats a small price to pay on avoiding an expensive mistake, if the mech check fails.
I will need to fix that door and the rear panel next to it though. Not a roadworthy issue but I cant stand things not straight.
Despite the fact it was probrably a little silly making a decision so quickly - I wouldn't stress too much. Chances are the car's still half decent. If it's had accident history that doesn't matter greatly either - as long as it's been repaired correctly.
Correct, but make sure the parts are correct items too.. i dont consider a fibreglass $300 copy of a bar appropriate for a gtr that should have a plastic bar that is worth $1700. And thats just an example.
If in doubt, get someone from the forum who knows more to go with you.
This sounds really sus, like its been smashed in the front end. look at the bolts fastening the front quater panels. Also look at any other bolts that fasten panels to see if they are new or are freshly painted over. Loof at the fmic mounts, pipe hose clamps etc. Have a look down the side of the car to see for straightness. check the hose clamps and fastners etc on the engine too for replaced parts. Be very very careful mate! good luck, hope you can find a good GT-R! :)
-rb25
N/A you would do me a great service by PM ing me
all details so I can work out if it is indeed the very
same car.
You continue to leave clues and abstract comments
without helping someone out.
Is this too much to ask, or are there other issues
at play here?
If PM is no good feel free to email
[email protected]
If u are thinking that I should have enough info
to go on with you are wrong I need better
evidence so I would appreciate some help.
Thats not an unreasonable request is it?
White smoke can mean water is in the exhuast, also meaning steam.
It can also mean there could be a water leak into the engine from the water system, or water in the oil.
Get it checked out and decide after that, it shouldn't be of any great loss to you either way it goes.
I was watching some doco on National Geographic, and for the smoke that comes out of the back of those stunt planes, or the formation planes at the air shows, they said they dropped oil on the exhaust and the heat from the exhaust causes the white smoke? So don't know if that applies to a car, with an oil leak on a hot exhaust? Altho, if it happens as soon as you turn it on then goes away when it gets warm, that contradicts that idea a bit doesn't it?? Oh well :D
Good luck with the buy. I bought a car in japan a few months back, description was good and pics look ok, just hoping she's alright when it gets here. Hard to tell even when inspecting a car in person, let along not seeing the bloody thing :)
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
