Pardon me please if this is in the wrong section but I was hoping someone could give me advice.
I have Nismo R32 GT-R #167 and I'm in the process of fixing her back up to her former glory. To that end I plan on adding several Nismo parts. I already have a Nismo clutch going in to replace the heavy-ass one already in the car and upgraded Nismo engine and gearbox mounts. The place I bought the car from gave me a period-correct Nismo wheel to slap on. I got a Nismo 320kph speedo off eBay. Eventually I want to get some other bits like a Nismo gear knob, seat covers, etc.
One thing that eludes me though since AFAIK it's been discontinued is a Nismo intercooler. Since my R32 is an authentic Nismo GT-R I think it would be great to have a Nismo logo proudly showing on the front but where could I get one? All the shops I've cheked online just have it listed as discontinued. Anyone know of anyone who wants to part with one? Any chance Yahoo auctions or another similar site might have one? Any leads would be greatly appreciated.
If I can't find one it's not the end of the world for me. I'll probably go with a Blitz intercooler or similar in that case but it sure would be cool to have an authentic Nismo IC for my authentic Nismo GT-R :)
Oh,and is the R32 intercooler unique from the R33 and R34 or were they all the same, just differing in piping?
Thanks in advance for your help.
Edited by GSX-R35
yahoo will have one floating around.
oh also the nismo wheel, if it requires a boss kit to put it on Nismo did make one. They are quite hard to find but hey, nismo!
Sounds like I have to hit up Yahoo auctions then. Thanks. As for the wheel, I do need a new boss kit for it. My car has a Momo wheel on it and I was told the kit it uses won't work with the Nismo because the bolt pattern is different. I'm okay with a non-Nismo made boss kit like a Works Bell or NRG though. You wouldn't happen to have suggestions on which kits from either of those companies would work with a Nismo wheel by any chance or any suggestions on other brands to consider? I've done some research on it but haven't settled on a firm answer since I've been more occupied with sussing out parts for needed maintenance and repainting of my car. I'm hoping to put it in for respray in July and after that restore the interior so the wheel situation has been on the back burner for now.
I thought Boss kits are universal... What nismo wheel is it? There is a few variations. Mine is sitting next to me currently. I would say you can use the boss kit that the momo is attached to...
The earlier nismo intercooler is identical to an 70mm ARC intercooler, the later one which came out after R34s were released is a 100mm item
The later version is possibly also ARC, but if so it comes in a polished version not normally available from ARC.
I have the early nismo one on my 32.
If you find a R34 intercooler, it will fit, but it just has an air temp bung to use or plug on the drivers side of the FMIC.
The Nismo wheel I have is identical to this one (only with the leather in better shape):
The Momo that's on right now is identical to this one:
They both have a six bolt pattern but I was told that the boss kit I have wouldn't work because the orientation is different - the Momo has the top screw at 12 o'clock while the Nismo has two top screws at 11 and 1'oclock. Sorry but I don't know nearly enough about aftermarket wheels and boss kits to say otherwise so I'd appreciate the correction if I was told the wrong thing.
Edited by GSX-R35
Thanks for the info. So with the R34 IC (if that's what I can find), that air temp bung can be closed off for use on the R32 and no other modifications needed? Just want to make sure I understand correctly.
Given that the top end of the steering column is splined, I would have thought that adjusting the alignment of the boss would be to the resolution of 1 spline.
  • Like 2
same nismo wheel i have ^^
The boss kit should work. What GTSBoy said^^
Thanks for the info. I'll have to pull off the Momo wheel when I get a chance and see what's up.
I saw that auction when I did a quick search on another Yahoo auction search site. I wish it had pics that were more close-up cause it seems to have a lot of bent fins.
that is a very early model nismo intercooler that is made by ARC. Those are pretty rare also. I emailed for better pics, but no response. It does look pretty beat up, so I passed as well. It has been up for a very long time. I bought a decent newer style r32/r33 off the auctions. Only one i've seen in about 6 months.
After some fin straightening
It looks different than my ARC intercooler. Notice how it triangles out between the rows of fins . I dont remember that on my nismo. I am not home, so I cant check.
Edited by JTCC
Yeah, I wasn't digging the condition of that old Nismo. I don't mind it's an earlier style since it's period correct for the car but it just looks pretty worn. If it were a lot cheaper I might bite but not for $1K.
What are you planning on doing with your ARC now that you have two intercoolers? Are you considering selling it?
Its on my rb25 s13.
  • 1 year later...
I have one for sale brand new in box. $3,400 plus shipping. contact me through instagram at superb_rated
Dang, that is a very pretty IC! The want is strong but unfortunately I don't have the budget right now with my build still finishing up. I'd be interested if my build were finished but that's still a couple of months away by my estimate.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
