A set of Rays TE37SL goodness made by Rays Engineering, this set is used however its in new condition as it was used on a Track car only. The TE37SL is the updated version of the famous TE37, which is lighter and offers more rigidity compares to the older version.
All four wheels are 18 x 10.5 +15 offset PCD 114.5 with NO Gutter Rash, it offers huge brake clerence.
All four wheels are fitted with Toyo R888 Semi slicks 295⁄30⁄18 with 6mm tread on all four tyre, manufactured on the 21st week of 2013 and has been stored in a cool dry place wrapped in plastic. the rubbers still soft!!
There is no heat spots or tares on the tyres, these are one of the best track day tyres on the market, with great traction and tyre wear durability.
These are great value for money, tyres and wheel are well over $5000 when new, also these wheels keep their value for the years to come!
Wheels and tyres can be seperated.
Asking $3550 ONO for the set.
Located Mortdale 2223
Can post anywhere at buyers expanse
Please contact me on 0416 766 449 or PM if you have any more questions
DSC01250_zpsvs8tlnkw.jpgDSC01252_zpsujbjq6jc.jpgDSC01253_zpsadf9fkbk.jpgDSC01254_zpskavkrkt0.jpgDSC01255_zpsyq2auzem.jpgDSC01256_zpswu3wfisz.jpgDSC01257_zpstdvmdjix.jpgDSC01258_zpskbhu43mj.jpg
Edited by roy8532
    • This, honestly, is entirely BMW life. There's so many little things that once you know about you are either more relaxed or more uptight! 🤣 Fwiw (and slightly in my defence) our X5 has been flawless! The biggest issue we've had was problems with the front diff which ended up with a 2k rebuild but other than regular servicing with good oil and filters we've had no out of the ordinary costs or problems. it's been amazing and we've put 90k on it over about 5 years.  It's just the other two. The problem kids.
    • The more I think about it, the more I should probably go with a genuine Bride seat and rail set up. But damn the $$$ for a driver and passenger seat + rails!
    • From what I understand, stock internals should hold out for a while even if you run 500 at the crank, no? Especially if you don't run a modern turbo setup that reaches power and torque much earlier than the original twins. My engine isn't unopened either, it has N1 Pumps, head oil restrictor, new crank and cams, new piston rings, ARP head studs and Cometic headgasket along with 2860-5s. Considering everything is healthy this should run fine for a while I assume. Once my engine stops leaking shit everywhere, it'll be tuned to 370 crank first anyway, because I need to legalize the turbo setup. If I end up needing a new engine because my block actually has an issue, even though GTSboy was adamant that the whole porous block story is nonsense, before putting an engine in I'm probably gonna take care of the weakspots.
    • Hah, I have no issues with what you are doing whatsoever! You clearly know what you are getting yourself into. It's just funny reading things like this. "What's that noise?" "Oh, that's normal. That's just the engine not getting any oil. Nothing to worry about. It'll go away in a moment"
