I know how tuning works.
I posted the thread for positive answers, and as to where I stand legally over the password protection and him trying to make me pay him hundreds of dollars to unlock the computer.
I have no desire to play with the tune that is in the car, nor have anyone else play with the tune.
I simply wanted to be able to access it for diagnostics, as I said previously.
Well as a photographer, clients commission my work and own the rights to do with as such they please, unless I expressly reserve copy write, then said work is given at a much cheaper rate, all of which is contracted.
The tuner is paid to tune an individual car, not write a program that anyone can use, as such no intellectual property rights exist.
  • Like 2
To protect your Patents, Trade Marks and Copy Rights, I thought you also had to have them examined to make sure you are not infringing on someone else's IP and to do this you have to pay for the luxury and it is not cheap, then to keep them there is an annual fee.
I find it hard to believe that someone tuning your car can claim it as IP. Who else would want a tune done for your car and if you were going to another tuner, he would probably think his tuning skills are better anyway. IP protection is very expensive, so????
Anyway, if you can disregard the tune on your ECU and have another tune installed, who gives a shit :)
  • Like 1
When someone payed Leonardo da Vinci to paint Mona Lisa, Leonardo couldn't say "hey you can't draw a mustache on that lovely pout" etc, the persons who commissioned the work owns it, and can do what ever they please with it, i.e. copy it re-draw it, freakin burn if they choose.
...P.S. I've never found any mechanic/ workshop who would give a written quote/ on any repairs/ work , every time I've asked for a written quote I've got nothing but silence, or told to pis'orf
  • Like 1
I think this thread is a dead end.
The Ecu is locked. Got it
You got a new tuner to look at it? So what happened? He couldn't give you a new tune? Or that wasn't the problem?
I still firmly believe that there are 2 sides to each story and your side sounds not so compelling.
the op will decide that not you
Yeah, I think once the question is answered by someone that knows what they are talking about, then it will close itself :)
Is there a Patent Attorney out they in SAU land ????
I reckon it is stupid to think you can still own a procedure that someone else has paid you to do, UNLESS you have made some dumbarse written agreement..
  • Like 1
To Hadouken
Please read the original post which I have re-posted for you.
Take extra notice of the last sentence.
Seeing as this is a forum which relies on people being able to read English.
Long story short, bought a r32 gtr, soon after purchase it stopped and wouldn't start again due to electronic issue, can't access computer due to it having a password, rang the mechanic/tuner who was looking after the gtr, he won't give me the password, and will only unlock it if I give him $400-$500, he (Simon and Greg) from bayside/Southside dynos is in Brisbane and I am located over 100kms away.
Can anyone help me with either a way to get around the password or with legal action against this flamin mongrel???
Edited by Jhols1, 12 June 2015 - 05:00 PM.
I think it is more on why can they lock it and say it is their IP , it would be great to get the answer to the question.
Do they have the legal right to lock your ECU and not give you the password without holding you to ransom. They were paid for the work and then they want money to give you your tune back to you :/
  • Like 1
not true in NSW, although I don't know about QLD. In NSW they can even make enforceable findings, although if they are ignored you need to take the further action (CTTT or local court) if you do need to enforce them
in nsw they did sfa when i informed them of a company who was trading with a cancelled abn and insurance. Even when i had proof of their dodgy work and a quote and receipt with all the info on it.
edit: I called multiple times and spoke to multiple people.
Which type of ECU is it? Perhaps give the their tech support a buzz and see if there is anything they can do for you or can suggest to bypass the lock.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
