Hi All,
First and foremost, I am overwhelmed with the support shown from SAU NSW Members and friends. I thank you all from the bottom of my heart for even thinking of me and my family to organise an event to support us. That is something that I will never forget and appreciate greatly. This community has given me many great times in previous events, long lasting friendships and much more. I can now add this support to that list. Unfortunately I hadn’t kept up with the events forum in recent times and missed that this was on even though it was in my own backyard! But it looks like it was a great success and everyone had a great time. Congratulations to the organisers.
My daughter Olivia is an amazing young girl that takes everything that's thrown at her in her stride. I have learnt a lot of things from her during this time. Patience, caring, acceptance and many other great qualities I would not have had it not been for her. She is currently in her 4th month of Chemotherapy and has 2 months to go. As explained in the first post, Olivia had surgery to remove her kidney tumour and a couple of weeks later started radiation and chemotherapy. Looking on the bright side, we have a beautiful 4yr old girl to cuddle at night and to that end we thank Sydney Children’s Hospital, the Oncologists, Surgeons, and Nurses for their amazing hard work. Without them she would be here to brighten our days.
I am sure most of you have somehow been touched by the disease that is cancer. Some more personally than others. As a father, I sometimes struggle to understand how and why a child could be diagnosed with cancer, but the same feelings as a father help me cope with the events that have unfolded over the last 5 months. 600 parents of children get told each year in Australia that their child has cancer. While that number seems small, it’s 600 too many.
Your support is amazing and greatly appreciated.
TL:DR
Thanks a bunch guys!
Jason & Family.
  • Like 13
Twas a pleasure to be part of this charity event Jason.
Yes my wife is a cancer victim > survivor and we can relate to what you've been going through.
I personally have noticed your parts in cycling for cancer causes in years gone by and have lauded your contributions in these.
God bless...
  • Like 2
God bless...
The cycling I've done in previous years was for Multiple Sclerosis, which we raised over $45k for over the years. I will strive to fund research into childhood cancers into the future as much as I have with MS in the past, Thanks for noticing :)
  • Like 3
Quick question on cancer to those that know more than I. ..
why are there so many separate charity's and foundations working on it, instead of pooling all the sources and research together so they aren't double testing dead ends?
alot of charities revolve around cancer, but are not actually for the research of cancer itself, the study to cure cancer isn't the only purpose.
For instance, the McGraph foundation is a breast cancer support foundation, it provides nurses to care for sufferes of breast cancer and their family. For all intents and purposes, their core goal isn't to try and cure it but help people survive it.
many other causes are stuff like:
cancer awareness
support for sufferers
support for their family
treatment care
post care
mental care
living expenses
medical expenses etc.
Of the charities that are in the research category, I do beleive alot of information is shared between the research institutes.. It's also noteworthy to understand that cancer of the breat is different to testicular, prostate, bone etc. and each one reacts very differently to treatements and potential cure research.
They beleive that a cure for testicular cancer is going to be easier than bone cancer as there is less genetic make up in a testie. (I saw this in a doco and it might be the other way around ie; easier for bone than testicular..... someone correct me if i have it mixed around) ????
  • Like 3
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
