i've got an r33 gtst, and roughly once a week i get an idling problem for about 15 secs once i start the car.
what happens is once i start the engine, the revs (like always) first jump up to roughly 1400rpm or so, and instead of dropping down to 1100rpm for a minute or so it keeps jumping up and down between 600 and 1400rpm. this happens for about 15 seconds and if i give it a bit of throttle, eventually it stops and idles normally again... and like i said before.. what spins me out the most.. is that it only happens once a week or so...
was told by a novice (like myself) that it could be a leaky bov??
:confused: !!!
help please!
babs...
https://www.sau.com.au/forums/topic/45745-idling-problems/
it could be a inlet manifold gasket leak, has happened to me with the GTR, took me ages to diagnose!!!!!I mean Hours and hours....looking at the ICS and the cold start valve etc etc .
grap your self a can of brake cleaner in a aerosol can preferrable one with the small white tubing you can stick in the nozzle, like on those cans of CRC, and run the car,
carefully and I mean carefully coz this stuff is flammable, spray along where the inlet manifold meets the side of the cylinder head. Also spray into the injector bungs where the injector nozzle sits in the inlet manifold.
I had about 1inch missing in my inlet manifold gasket and 3 of the 6 injector bungs very leaking like a sieve!. The vacuum sucks in the flammable brake cleaner and it will cause a very noticable engine stumble. You'd have to be deaf to miss it.
Give that a try, can save you hours and dollars.
If the ICS or the cold air valve were faulty the idle would usually stay high all the time even when warmed up.....Checking them however is relatively easy so start with the brake cleaner and go looking for vacuum leaks first....
https://www.sau.com.au/forums/topic/45745-idling-problems/#findComment-930833
Check radiator coolant sensor on bottom left side of radiator(green plug up top) Check with multimeter to see if u got a circuit. Mine has the same problem but havn't gone to Nissan yet to get a new one.
(Just found out that sensor is actually for the electric fan,my mistake) :Oops:
https://www.sau.com.au/forums/topic/45745-idling-problems/#findComment-932549
Apart from the rough idling what other problems can this cause? Flat spots higher in the rpm? Popping from the exhaust on down shifts? Weird on/off boost?
hmmm i do seem to be experiencing this too.. but without the exhaust popping..
have got flat spots occasionally and boost is very unpredictable.. very wierd i must say
https://www.sau.com.au/forums/topic/45745-idling-problems/#findComment-971192
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
