Set of 6 ev14 injectors for sale, includes harness and height adapters.
Injectors are 850cc half height, works well on the r33 rb25, the height adapters will extend the injector height to 3/4, suitable for greddy plenum with aftermarket fuel rail.
They work exceptionally well, car ran and idled really smooth with these.
Harness adapter is for r33 GTST, not sure if it's the same for GTR
Height adapter is for 14mm o ring
Will not fit r34 GTT
Reason for sale: originally came off my old r33 GTST, will fit r33 GTST RB25 with the right fuel rail or rb26 on r32 - r34 GTRs, only used for less than 5000km, selling as the car was sold
$400, can post at buyers expense
  • Like 1
  • 3 weeks later...
I can confirm that this will fit:
R33 GTST rb25 with aftermarket fuel rail, standard plenum (will need to take off the height adapter)
R33 GTST with greddy plenum and aftermarket fuel rail
R34 GTT with greddy plenum and aftermarket fuel rail (will not fit r34 standard plenum)
Wiring loom plugs straight in for the above vehicles, not sure about Rb26 or R32 gtsts
You'll need to do away the resistor pack on the rb26, you can rewire using the loom supplied than cutting your existing loom, allowing you to convert back to stock if you ever need to
Edited by chiksluvit
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
    • Some sense has prevailed! What kind of idiot spends money on intake, heads, and cams for a N/A motor in 2025? Lol. What maroons. Source:I am King Maroon.
    • So, cams are not getting installed......yet  Had a good chat with MX5 Mania about intakes, they recommend not to get ITB's, they recommend a plenum style for the NC So, one of these puppies is being ordered, with a larger TB to suit, when it arrives from the US the car will go in for the cams and intake I'm also getting a fancy rear box bit for the air filter box which will suit the new TB size
    • Clamp meter is pointless. Unless you're trying to keep average current under a set value for some weird reason (maybe you undersized your wiring?), then you'll get no useful info. What you're really trying to target is the flow of fuel coming back to the tank. You want some, but not a lot. You also want to make sure fuel pressure remains stable.   So, fuel pressure gauge, and fuel flow gauge. Set it up from that.
