Set of 6 ev14 injectors for sale, includes harness and height adapters.
Injectors are 850cc half height, works well on the r33 rb25, the height adapters will extend the injector height to 3/4, suitable for greddy plenum with aftermarket fuel rail.
They work exceptionally well, car ran and idled really smooth with these.
Harness adapter is for r33 GTST, not sure if it's the same for GTR
Height adapter is for 14mm o ring
Will not fit r34 GTT
Reason for sale: originally came off my old r33 GTST, will fit r33 GTST RB25 with the right fuel rail or rb26 on r32 - r34 GTRs, only used for less than 5000km, selling as the car was sold
$400, can post at buyers expense
  • Like 1
  • 3 weeks later...
I can confirm that this will fit:
R33 GTST rb25 with aftermarket fuel rail, standard plenum (will need to take off the height adapter)
R33 GTST with greddy plenum and aftermarket fuel rail
R34 GTT with greddy plenum and aftermarket fuel rail (will not fit r34 standard plenum)
Wiring loom plugs straight in for the above vehicles, not sure about Rb26 or R32 gtsts
You'll need to do away the resistor pack on the rb26, you can rewire using the loom supplied than cutting your existing loom, allowing you to convert back to stock if you ever need to
Edited by chiksluvit
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
