I don't have the Spool built short motor but I purchased the 3.4 rotating assembly and had my engine builder do the work.
Airflow through the head is hugely important, don't skimp on this. I personally wouldnt put cams bigger than 270 as you don't need the revs especially for street use, make sure you degree them with a dial indicator. With my 26 head and 1mm OS valves, 10.8mm lift and 260 degree procams, mine makes peak power just before 8000rpm with a broad torque curve from 3000rpm. Turbo is a 6466 with twin-scroll 1.0AR hot side. Has made over 800rwhp on 28psi but its useless at this power, I actually prefer gate pressure which is 14psi creeping to 19psi and about ~550rwhp
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7560885
Cootamundra??? Do you mean Temora???
and your talking hp in the thread but quoting kw in your sig, just wondering is all. 550 rwhp isn't anything too unusual - would have thought that you would get more with no real effort, thus my question re kw vs hp - but the torque would be phenonemal.
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7561584
No I mean Cootamundra. Motive DVD Drag Battle.
KW/HP.. They're one and the same, sometimes ill quote one or the other haha. Ive made the peak power number that im comfortable running, and the car is useless like this. I prefer the car with around 400-420rwkw (540-560rwhp) as its the least 'scary' to drive and is still plenty enough to bake 3rd gear at 100kmh. Remember we're talking peak numbers here. The car still has 300rwkw at 4000rpm regardless of my peak power so yea its 'torquey'
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7561686
Have now found a Neo head locally so have put an order in for a pair of Tomei 143023 B cams
Strangely finding a matching RB25 Neo or later R34 cas unit seems harder to find then the head was ?
Still need to find one or start looking at other ways of timing ?
Haven't looked into much else yet and tbh I didn't think about getting the head ported but its not to say I won't
What power will a std Neo head run to anyway?
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7562024
760 at the wheels? So over 800 at the crank as a standard head/ports and valve sizes?
Yep I would personally be going to a crank trigger setup. There is a group buy on here at the moment for only $350 or so + machining of the harmonic balancer.
Cheers I will have a look for the thread. Am using a link g4 and have a aftermarket crank damper so I assume it will be compatible ?
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7562421
Cheers, what are you guys using coil wise with the Neo head ? Matching Neo coils or adapted Gtst coils?
Car is using S1 Gtst electrics so still runs a separate amp
Only I've have a set of as new Nissan OE Gtst coils and although haven't tried it looks like their mounts are all out ?
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7562458
You can adapt and make any coil work, with or without separate ignitors
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7562967
Sounds good
You got a dyno graph to look at?
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7566482
  • 6 months later...
wow, I think that mota & car build might be a bit more involved than mine lol
Have gone for the motor only on mine as tbh once this is built I plan to leave it be
Famous last words ...
As it is I've got my mota built up and in the car, but am now waiting on getting the exhaust manifold modded
Hopefully I will get sorted soon
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7674345
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
