these are the parts that i have left no reasonable offer denied
rear bar grey in colour bit faded $40
reinforcement behind rear bar $15
front seats out of m spec immac $300
rear seats out of m spec $90
grey carpet $40
grey hoodlining $30
fuel tank with fuel pump and sender $50
rear window $100
left hand quarter window with rubber $50
rear sub frame with hubs & control arms SOLD
gts4 or gtr front hubs control arms and struts $80
ac compressor $40
manual tail shaft $40
all plastics from center console and radio facia
brake master cyl with pipes and abs unit $100
A PILLAR TRIMS $25 EACH
LH POWER MIRROR $40
complete top end rb20det head, manifolds, turbo wiring, computer asking $400
no gearbox
no coils or ignitor
no dash or vents
https://www.sau.com.au/forums/topic/45748-wrecking-r32/
is the boot charcoal metalic or gray as described???
Also do you have the metal lining that goes around the rear windo its a three piece metal strip thing???? PM me your mobile and i can have a chat about some stuff and prices!!!
https://www.sau.com.au/forums/topic/45748-wrecking-r32/#findComment-931254
Need 2 x o2 sensors out of GTR r32 , the ones that scew into dumps , must be working please.
boot lid imac with wing off m spec gray in colour $90
rear bar grey in colour bit faded $30
both doors with all internals and glass . no door trims $200
grey carpet $40
grey hoodlining $30
rear window $100
rear sub frame with hubs & control arms $80
ac compressor $40
no gearbox
no coils or ignitor
no dash or vents
https://www.sau.com.au/forums/topic/45748-wrecking-r32/#findComment-931497
no gearbox
no coils or ignitor
no dash or vents
What about the underbody plastic bit RHF Guard - protects the BOV are from road dirt?
Odd screws/connectors from the bumper etc?
R32 GTR not sure if other cars are different
https://www.sau.com.au/forums/topic/45748-wrecking-r32/#findComment-934827
Hey man if you know if the R32 drivers side window is the same as an R33 and in good condition send pic if possible i'll take it plus its internals $130 and i'll front the shipping.
PM me. thanks
i'd say it would be different
https://www.sau.com.au/forums/topic/45748-wrecking-r32/#findComment-939147
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
