Hey guys have the Threebond Engine Conditioner for sale [same stuff as the Subaru UEC]
As most of us know the VQ's are prone to a lot of build up in the plenum chamber and cleaning it out by stripping it down is much effort of some people. with the Threebond Engine conditioner its designed to be used to clean it up without much disassembly at all.
Price:
1x $13
2x $24
3x $36
can post Australia wide for $7.50 max 3 cans
Pick up Brisbane South
Contact: Spencer 040070098one
Some details of the Threebond Engine cleaner:
Motatec Threebond Engine Conditioner (Petrol) cleans the induction system & combustion chamber on your petrol engine by removing carbon, varnish, sludge & gum all without dismantling major parts of the engine.
  • IMPROVES PERFORMANCE
  • REDUCES PINGING
  • IMPROVES FUEL ECONOMY
  • HELPS SMOOTH ROUGH IDLE
  • REDUCES POLLUTION
  • HELPS COMPRESSION RATIO
  • Use every 15 000km service or 6 monthly.
  • Suitable for vehicles with catalytic converters
  • O2 sensor safe
  • Use only on cable-operated throttle, if electronic throttle consult your dealer BEFORE using.
  • NOT TO BE USED ON DIESEL ENGINES - SEE Threebond Engine Condition Diesel 3B-DEC
  • No CFC
  • LPG Propellant
  • Flammable Gas 2
INSTRUCTIONS FOR USE:
  1. Warm engine to normal operating temperature. Shake can well.
  2. Stop engine, remove a convenient vacuum hose from intake manifold/throttle body.
  3. Spray for approx. 15 seconds.
  4. Allow to stand for 5 minutes before proceeding to next step.
  5. Start engine and accelerate enough so that the engine doesn't stall. Empty remainder of can into intake manifold/throttle body.
  6. When can is nearly empty stop engine and allow remainder of conditioner to sit for a further 5 minutes.
  7. Re-attach vacuum hose.
  8. Start vehicle and run for minimum 2 minutes before road testing vehicle.
https://www.sau.com.au/forums/topic/457508-fsthreebond-engine-conditioner/
Eh?
This product does nothing for the direct injection mess in the runners, even if you let it sit and soak in it overnight.
Aren't all VQ's electronic throttle? I know VQ35HR and VQ37VHR are electronic.......
the VQ has been around since 1994 and the 2 examples you list are from 2007 at the earliest.
so no, not all are e-throttle.
With the electronic throttle body what I've done to my personal v35 and a few 350z is where the left bank breather hose to the intake is where I pumped it in. If you have not taken apart your plenum to clean it up its a good idea to do that not necessarily use this product but if your lazy to take it apart this product will sufice. I do it every 2nd service to maintain and keep my throttle body carbon and sludge free and help clean the intake and plenum, possible even clear up some unburnt carbon build up on the piston head.
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
