Hey guys have the Threebond Engine Conditioner for sale [same stuff as the Subaru UEC]
As most of us know the VQ's are prone to a lot of build up in the plenum chamber and cleaning it out by stripping it down is much effort of some people. with the Threebond Engine conditioner its designed to be used to clean it up without much disassembly at all.
Price:
1x $13
2x $24
3x $36
can post Australia wide for $7.50 max 3 cans
Pick up Brisbane South
Contact: Spencer 040070098one
Some details of the Threebond Engine cleaner:
Motatec Threebond Engine Conditioner (Petrol) cleans the induction system & combustion chamber on your petrol engine by removing carbon, varnish, sludge & gum all without dismantling major parts of the engine.
  • IMPROVES PERFORMANCE
  • REDUCES PINGING
  • IMPROVES FUEL ECONOMY
  • HELPS SMOOTH ROUGH IDLE
  • REDUCES POLLUTION
  • HELPS COMPRESSION RATIO
  • Use every 15 000km service or 6 monthly.
  • Suitable for vehicles with catalytic converters
  • O2 sensor safe
  • Use only on cable-operated throttle, if electronic throttle consult your dealer BEFORE using.
  • NOT TO BE USED ON DIESEL ENGINES - SEE Threebond Engine Condition Diesel 3B-DEC
  • No CFC
  • LPG Propellant
  • Flammable Gas 2
INSTRUCTIONS FOR USE:
  1. Warm engine to normal operating temperature. Shake can well.
  2. Stop engine, remove a convenient vacuum hose from intake manifold/throttle body.
  3. Spray for approx. 15 seconds.
  4. Allow to stand for 5 minutes before proceeding to next step.
  5. Start engine and accelerate enough so that the engine doesn't stall. Empty remainder of can into intake manifold/throttle body.
  6. When can is nearly empty stop engine and allow remainder of conditioner to sit for a further 5 minutes.
  7. Re-attach vacuum hose.
  8. Start vehicle and run for minimum 2 minutes before road testing vehicle.
https://www.sau.com.au/forums/topic/457508-fsthreebond-engine-conditioner/
Eh?
This product does nothing for the direct injection mess in the runners, even if you let it sit and soak in it overnight.
Aren't all VQ's electronic throttle? I know VQ35HR and VQ37VHR are electronic.......
the VQ has been around since 1994 and the 2 examples you list are from 2007 at the earliest.
so no, not all are e-throttle.
With the electronic throttle body what I've done to my personal v35 and a few 350z is where the left bank breather hose to the intake is where I pumped it in. If you have not taken apart your plenum to clean it up its a good idea to do that not necessarily use this product but if your lazy to take it apart this product will sufice. I do it every 2nd service to maintain and keep my throttle body carbon and sludge free and help clean the intake and plenum, possible even clear up some unburnt carbon build up on the piston head.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
