Hello All,
Time for a bit of a garage cleanout.
Postage: Local Pickup for wheels and tyres. Can post the rest
Email: [email protected]
Item 1: $1400ono
17x9+22 Enkei RPF1 with 255/40/17 Federal FZ201 Mediums x4
I bought the wheels new from Autotechnik and put on my track car that does maybe 2000k's per year.
Tyres bought new about 12 months ago off the forum. Have done 4-5 Queensland half track days.
Still got 4mm tread left.
Wheels are immaculate.
Not going to separate wheels and tyres.
Item 2: $250
Hankook Ventus RS3 255/40/17 x4
Have done a few track days and have been in storage in my garage for 12 months. Still plenty of tread left.
Item 3: $300
Genuine Garrett 0.82 IWG GT30 series T3 exhaust housing. (Came off GTX3076)
Come with garrett 16psi actuator
Bought new with turbo a few years ago. Done maybe 5000k's. Excellent condition.
Item 4: $99
Brand new Kinugawa adjustable GT30 series waste gate actuator with 5 springs (0.5, 0.8, 1.0, 1.2, 1.5 bar)
Item 5: $200
Custom made stainless steel front and dump pipe to suit above housing (GTX30 0.82 IWG)
Made by Sabbadin Automotive - work of art!
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
