On 9/2/2016 at 11:26 PM, Gillyr33gtst said:
38mm instead of 33mm from the guide for the tensioner hole no need to use two tensioner and timing marks line up spot on
Can you elaborate on this? I don't understand how the tensioner hole position has any influence on the timing marks. The drive side of the timing belt is phasing the belt teeth based on the length of the path the belt follows. I reckon using an idler pulley doesn't get the crank to cam sync quite right. The other thing is that the timing marks on the head backing plate are probably only as accurate as they needed to be assuming you were putting a timing belt back on an RB25 block (ie you aren't wrong by a hole tooth). I am probably thinking about it too much and if I truly want to get it right I would need to dial the crank to the cams properly. Thanks for the help!
You are able to get the right tension on the belt from the beginning and the tension is on the correct side and not relying on the second tensioner to get it right I found when using the two tensioners I'd be playing around with both of them to get marks lining up now the extra 5mm and one tensioner and Idler I'd set tension and marks are perfect hope I explained my self clear enough I'll dig up some pics and post of this
Cheers for that. I've ended up going with the two tensioners.
A little update, I got it running tonight. I nearly fell off my seat it was so loud running straight off the headers right next to me.
I set up an oil pressure gauge in my little switch box and it's making plenty. I only ran it for a few seconds since there's no water in it yet.
  • Like 2
I slapped a radiator and short exhaust on it this week. Sounds absolutely awesome. Very crisp and revvy. All I need now is a car to whack it in.
Does anybody have any good ideas about converting it to a Programmable ecu? I'm am idiot and didn't look into this and now have the issue of doing one if these things.
1. Buy a complete turbo loom and ecu and injectors then going nisstune.
2. As above but plugging in a pfc
3. Start from scratch with a aftermarket loom and ecu. I would be thinking megasquirt if going down this path.
Any advice would be welcome.
Dave
T
Edited by dave1200
Thanks but Not sure this helps me. The problem is that the Neo NA ecu and loom are different to the turbo therefore any of the plug and play ecus won't work because nobody supports the NA motor. If I have to wire one from scratch it will be a megasquirt but I'm mostly looking at the pros and cons of replacing loom with a turbo then getting a plug and play ecu/piggyback nistune style. I think I can get a megasquirt running the complete NA motor then would just need to change injectors and go to map sensor to run a big turbo but this would have much more head scratching than the other option.
I'm a DIY kind of guy. You get incredible functionality for a good price. For less than $1000 I'll get an ECU that's entirely configurable with all the I/O of a high end ECU. As I said earlier they generate more head scratching but I've got a few mates who have had good success with megasquirt as well as know a tuner who is familiar with them.
  • 3 months later...
  • 1 month later...
get a Nistune, less money plenty of functions.
I have a tuner license too and can get you the boards cheaper. Since you're a DIY kind of guy it can be fun soldering.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
