Tuning And Intercooler Pipe Size
252mm to the centerline of the bottom mount.
Yes, well.... get the main wire off the back of the alternator and try again?
So.... here's one for @GTSBoy ..... I plugged up the battery in the boot, to my surprise no sparks, no shorts, alarm went off, dome light on, etc. tried to crank the car, motor rotated a few times. Battery is pretty flat so will need more juice before I try to start it. With the battery plugged up at the back, when you pop a volt meter across the chassis and the jump point, you get a nice 12V, no issue. However, when you disconnect the battery at the rear, you straight up get a short. My broscience is thinking there's some issue with the rectifier, dead diodes perhaps? -
Uses the same plugs as Ctek too, so easy swaps (when you've got the ring terminal thingo perma-wired to the battery, like I have.)
By No Crust Racing · Posted
Just shortens the charge time and allows more serious "rejuvenation" if you ever use that. 10/10 good buying.
