So the latest dick-head of the week, as I'm sure most of u would of heard about, was the Skyline doing 200 odd kays up Western Ring Road on L plates. Wow! Come on, this is why the police target performence cars, because there has to be a wanker who dosen't care for their lives or people around them. I think it shouldn't have happend. This is why it's becoming harder to go out and have a good cruise on a Sunday. What makes these people think ???? Share your thoughts on this please.
so the latest dick dick head of the week so as im sure most of u would of herd about the skyline doing 200 odd kays up west ring road on L plates wow come on this is why the police target performence cars because there has tobe a wanker who dosent care for there lives or people around them i think it shouldent have happend this is why its becomeing harder to go out and have a good cruse on a sunday what makes these people think ???? some times shear your thought on this please
Inserted some puncuations far ya :D A fullstop next time at least to help break up sentences.
Shan
https://www.sau.com.au/forums/topic/45755-what-was-she-thinking/
If she was on her L plates than it is the fault of the supervising driver. I cant believe that a parent or anyone else for that matter who is over 21 could allow someone who is only 16/17 to drive that fast, and sit next to them in the car! Idiots
They should be shot, its called euthanasia.
The Ring Road is definitely not the place to give the speedo a shake...
Regardless of the cameras.
I wonder what it would have been like if this forum was around 30 years ago. I can bet you we would be having "These new 0.05 laws are BS" threads every week. Because we would all be confident we know our limits. It is the same with our current attitude to speeding. We all think we are able to be responsible and pick the right time...
But how does the government work out which of us our kidding ourselves and which of us actually are responsible. Easiest solution is to get rid of the question ban all speeds above which Mr Clueless in his crapmobile can get into trouble.
was she pulled over or just caught by the camera's?
my guess is she is gonna fight and say that the camera's are broken and arent working and try to get away with it, meaning that she could of possibly planned it out like that.
hopefully she gets smacked on the head
http://www.theage.com.au/articles/2004/07/...9694458871.html
Oh dear...
At least we know police ignore anonymous complaints.
The thread in General says that she recently won $1.2million in the lottery!
LOL... oh well...
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
