This brand of filter has been mentioned herein on several occasions, but the posts are relatively old.
I have used a couple in the past and my car is coming up for another oil change. Can't remember why I chose this make of filter, and then except for perhaps cost, from what I understand, I don't see reason to change.
Thing is, despite my searching, I haven't been able to come up with a current Australian supplier - cost is an issue even in this case. I'm after a 15208-RN010
The prices asked to bring them in on Ebay are exorbitant.
Any clues out there please. I might have to go RHD Japan
https://www.sau.com.au/forums/topic/457573-nismo-veruspeed-oil-filter/
I used to buy Greddy oil filters from Autobarn, when they sold them for $20 and online retailers wanted $40 to $60. Realised it was a waste of money in the end since it gets chucked every 6 months.
Now I buy genuine Nissan filters in bulk instead, works out cheaper than Ryco retail
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
