Updated list:
1) Cusco Hicas eliminator aka delete $old; BNIB
2) Attain Hicas eliminator aka delete $49; BNIB
3) Exedy triple clutch r33/r32 push; NM033HRWH, $OLD; BNIB
4) Ogura triple clutch r33/r32 push 1000F; needs new plates $595; used
5) TRUST GREDDY SPEC-R HG FMIC KIT BCNR33 TWIN ENTRY TYPE 27 CORE; Notes:
R spec Intercooler, dim: 294x710x165mm (largest GReddy core), Inlet 70mm x 2, 100mm outlet, #12020440 ($2800 msrp) $OLD; BNIB
6) APEXi N1 r33/r34 Pro Drag racing Adjustable Dampers Coilover; Apexi remanufactured now in new condition ($2500 msrp) $1195
7) Brembo 2-piece 332mm = 13" front rotors (pair) for F50 Big Brake Kit $850; used
8) APEXi Super Brake Rotors #278-nr10 for factory r33/r34 Skyline GTR rear calipers, Cross drilled and slotted w/free new Apexi brake pads $275; BNIB
9) Non-VSPEC R33 GTR Rear Subframe and non-hydraulic mechanical R200 differential $old; used
10) Seibon CF R33 Jun style hood $599; used
11) Greddy non-vspec rear diff cover $old; BNIB
12) Mahle Pistons; no rings included $695; BNIB
13) APEXi N1 r33/r34 PRO Adjustable Dampers Coilover for circuit/track/street #263AN009; Apexi remanufactured now in new condition ($2500 msrp) $1195
14) Tomei 290 11.5 #1421 290115 r34 GTR WPC treated camshafts (pair) $OLD; BNIB
15) 2.8 Stroker Kit: HKS Step 2 forged pistons 87mm, Carillo Pro-H connecting rods, Crower.com (not BC) crankshaft; excellent condition, low miles $2995; used
16) Factory OEM Genuine r33 gtr wheels Falken good tires $OLD; used
17) r34 garage saurus cf ground effect (side skirts, front diffuser, rear spats); has cracks; see pics $OLD; used
18) r34 genuine top secret frp hood $499; used
19) r34 oem cf rear vspec diffuser $OLD; used
20) r34 N1 Race Super Taikyu cf reinforced front bumper with diffuser $450; used
21) r34 rear trunk lid (damaged, someone tried to pry open trunk) $45; used
22) r34 nismo white face gauge cluster 320km $OLD; used
23) r34 gtr xenon passenger LH headlight with Signal Auto hi-beam air duct mod w/free eye brow/lids uninstalled $OLD; used
24) r34 exedy triple clutch #NM053SR $1395; BNIB
25) r33 front bumper support reinforcement bar $45; used
26) Lexus SC300 leather steering wheel with airbag $75; used
27) PFC 7778.01.20.44 Race Compound 01 Pad 20mm Carbon Metallic front brake pads for Endless, AP, Alcon 6-POT BBK big brake kit $199; like new
28) Endless Matador Series MA22B Brake Pads for Endless, AP, Alcon 6-POT BBK big brake kit RCP052MA22B $OLD; BNIB
29) HKS T51R SPL full turbo kit (turbine, shield, manifold, wastegate, downpipe aka front pipe, intake pipe w/filter, screamer pipe) $OLD; used
30) r34/r33/r32 gtr front wheel bearings (front pair) $OLD; BNIB
31) r33 signal auto drag spoiler $399; used
32) Genuine Veilside race intake plenum aka manifold aka surge tank with throttle body, blue anodizing and the Veilside plaque had to be removed in order for the Wiggins to be welded on there; $1395; used
33) Apexi drag core 4 row intercooler, estimated measurements of 140mm thick, 80mm turbo side, 100mm intake side $1395; used
34) Hawk Brake pads HB180 HPS .591 for factory r33/r34 Skyline GTR rear calipers Ferro Carbon Street compound $OLD; new
35) Hawk Brake pads HB209F .583 for Honda Civic HPS compound $44; new
36) Centric standard brake rotors #121.42013 for 1990-1992 Infiniti M30 $39 for the pair; bnib
37) r33 GTR strut tower bar $95; used
38) r33 GTR rear seats $95; used
39) oem Pistons set from 1999 r34 GTR vspec, $150; used, one damaged
40) Hks version ati race damper #916060 (hks pulleys not included), $350, used
41) r33 oem power folding side mirrors in white, excellent, $99 for the pair
42) r33 GTR driver side door card aka panel, $50
http://orangecounty.craigslist.org/pts/5295750892.html
  • 2 months later...
Items added/deleted:
2) Attain Hicas eliminator aka delete $OLD; BNIB
6) APEXi N1 r33/r34 Pro Drag racing Adjustable Dampers Coilover; Apexi remanufactured now in new condition ($2500 msrp) $995
7) Brembo 2-piece 332mm = 13" front rotors (pair) for F50 Big Brake Kit $850; used like new
8) APEXi Super Brake Rotors #278-nr10 for factory r33/r34 Skyline GTR rear calipers, Cross drilled and slotted w/free new Apexi brake pads $OLD; BNIB
13) APEXi N1 r33/r34 PRO Adjustable Dampers Coilover for circuit/track/street #263AN009; Apexi remanufactured now in new condition ($2500 msrp) $995
15) 2.8 Stroker Kit: HKS Step 2 forged pistons 87mm, Carillo Pro-H connecting rods, Crower.com (not BC) crankshaft; excellent condition, low miles $OLD; used
24) r34 exedy triple clutch #NM053SR $OLD; BNIB
27) PFC 7778.01.20.44 Race Compound 01 Pad 20mm Carbon Metallic front brake pads for Endless, AP, Alcon 6-POT BBK big brake kit $OLD; like new
32) Genuine Veilside race intake plenum aka manifold aka surge tank with throttle body, blue anodizing and the Veilside plaque had to be removed in order for the Wiggins to be welded on there; $OLD; used
33) Apexi drag core fmic aka intercooler, 140mm thick, 700mm length, 260mm height, 80mm turbo side, 100mm intake side $995; used
37) r33 GTR strut tower bar $95; used, excellent
40) Hks version ati race damper #916060 (hks pulleys and bracket not included), $350, used, excellent
42) r33 GTR driver side door card aka panel, used $25
43) random engine parts: Intake manifold, alternator, oem hoses, fan, intercooler hoses, baffle, valves, pistons, r34 CAS (for parts), tension rod
44) Grex oil pump, used, excellent $750
45) Tial blow off valve, used, excellent $99
46) Samco intercooler hoses, new $75
47) clutch slave cylinder, used $25
48) pull to push transmission conversion kit, used $150
49) final drive, used, excellent $150
50) engine & transmission mounts, new $99
51) oem front & rear sway bars, used, excellent $99
52) transfer case, used $150
53) black mesh catch can hoses with fittings, new $60
Located in California but can and have shipped to AUS.
Prices in USD.
  • 4 weeks later...
Prices in USD. Shipping available.
Mostly, R32/R33/R34 skyline GTR RB26DETT parts for sale unless otherwise noted. More Pics available. Thanks for looking.
BNIB = brand new in box
1) Ogura triple plate clutch r33/r32 GTR push 1000F; needs rebuild kit from Nengun.com, $595; used
2) APEXi N1 r33/r34 GTR Pro Drag racing Adjustable Dampers Coilover; Apexi remanufactured now in new condition ($2500 msrp) $995
3) Brembo 2-piece 332mm = 13" front rotors (pair) for F50 Big Brake Kit $850; used like new
4) Seibon CF R33 GTR Jun style hood $599; used
5) Mahle Pistons; no rings included $695; BNIB
6) APEXi N1 r33/r34 PRO Adjustable Dampers Coilover for circuit/track/street #263AN009; Apexi remanufactured now in new condition ($2500 msrp) $995
7) r34 GTR genuine top secret frp hood with pins $499; used
8) r34 GTR N1 Race Super Taikyu carbon fiber reinforced front bumper with diffuser $450; used
9) r34 GTR rear trunk lid (damaged, someone tried to pry open trunk) $25; used
10) r33 GTR front bumper support reinforcement bar $25; used
11) Lexus SC300 leather steering wheel with airbag $75; used
12) r33 signal auto drag spoiler $295; used
13) Apexi drag core fmic aka intercooler, 140mm thick, 700mm length, 260mm height, 80mm turbo side, 100mm intake side $995; used
14) Hawk Brake pads HB209F .583 for Honda Civic HPS compound $44; new
15) Centric standard brake rotors #121.42013 for 1990-1992 Infiniti M30 $39 for the pair; bnib
16) r33 GTR strut tower bar $75; used, excellent
17) r33 GTR rear seats, top and bottom, $50; used
18) oem Pistons set from 1999 r34 GTR vspec, $95; used, one damaged
19) Hks version ati race damper #916060 (hks pulleys and bracket not included), $295, used, excellent
20) r33 gtr oem power folding side mirrors in white, excellent, $99 for the pair
21) r33 GTR driver side door card aka panel, used $20
22) random gtr engine parts: alternator, fan, intercooler hoses, baffle, valves, pistons, r34 CAS (for parts), tension rod, make offer
23) GTR Greddy aka Grex/Trust oil pump, used, excellent $750 ($1900 msrp)
24) Samco intercooler (new), breather (used) hoses and est. 30 meter rope 5mm x 2.5mm (new) $99 for the lot
25) GTR clutch slave cylinder, used $20
26) GTR pull to push transmission conversion kit, used $150
27) GTR engine & transmission mounts, new $75
28) R33 GTR oem front & rear sway bars, used, excellent $75
29) R33 GTR transfer case, used $150
30) Pair of black mesh catch can hoses with 1.5" fittings on both ends, like new $50
31) Adel Wiggins tube clamps100mm and 80mm clamps, qty 2 each, used, excellent $75 each or $250 for all 4
32) Greddy aka trust 80mm intercooler, 300x100x600, used, $895
  • 1 month later...
Updated list
1) Ogura triple plate clutch r33/r32 GTR push 1000F; needs rebuild kit from Nengun.com, $OLD; used
5) Mahle Pistons; no rings included $OLD; BNIB
7) r34 GTR genuine top secret frp hood with pins $OLD; used
10) r33 GTR front bumper support reinforcement bar $OLD; used
18) oem Pistons set from 1999 r34 GTR vspec, $OLD; used, one damaged
23) GTR Greddy aka Grex/Trust oil pump, used, excellent $OLD ($1900 msrp)
24) Samco intercooler (new), breather (used) hoses and est. 30 meter rope 5mm x 2.5mm (new) $OLD for the lot
26) GTR push to pull transmission conversion kit, used $150
27) GTR engine & transmission mounts, new $OLD
31) Adel Wiggins tube clamps100mm and 80mm clamps, qty 2 each, used, excellent $OLD each or $OLD for all 4
FYI - what's left. Also might sell Mines R34/R33 2-way with external reservoir and LMGT4 Limited Ed wheels)
1) APEXi #263A-N009-F N1 r33/r34 GTR Pro Drag racing Adjustable Dampers Coilover; Apexi remanufactured now in new condition ($2500 msrp) $995
2) APEXi N1 r33/r34 PRO Adjustable Dampers Coilover for circuit/track/street #263AN009-R; Apexi remanufactured now in new condition ($2500 msrp) $995
5) r34 GTR N1 Race Super Taikyu carbon fiber reinforced front bumper with diffuser $450; used
6) r34 GTR rear trunk lid (damaged, someone tried to pry open trunk) $25; used
7) Lexus SC300 leather steering wheel with airbag $75; used
8) r33 signal auto drag spoiler $295; used
9) Apexi drag core fmic aka intercooler, 140mm thick, 700mm length, 260mm height, 80mm turbo side, 100mm intake side $995; used
10) Hawk Brake pads HB209F .583 for Honda Civic HPS compound $44; new
11) Centric standard brake rotors #121.42013 for 1990-1992 Infiniti M30 $39 for the pair; bnib
12) Factory 33 GTR strut tower bar $75; used, excellent
13) r33 GTR rear seats, top and bottom, $50; used
14) Hks version ati race damper #916060 (hks pulleys and bracket not included), $295, used, excellent
15) r33 gtr oem power folding side mirrors in white, excellent, $99 for the pair
16) r33 GTR driver side door card aka panel, used $20
17) random gtr engine parts: alternator, fan, intercooler hoses, baffle, valves, pistons, r34 CAS (for parts), tension rod, make offer
18) GTR clutch slave cylinder, used $20
19) GTR push to pull transmission conversion kit, used $99
20) R33 GTR oem front & rear sway bars, used, excellent $75
21) R33 GTR transfer case, used $150
22) Pair of black mesh catch can hoses with 1.5" fittings on both ends, like new $50, also have another pair with 1.5" fittings on one end and open on the other end, $25
23) Greddy aka trust 80mm intercooler, 300x100x600, used, $895
Some cool parts I'm adding to the list. Postage from California. Prices in USD.
24) Authentic, rare Ganador Japan power side mirrors for a r33 Nissan skyline GTR, painted QM1 white, used, $599
25) Qest Japan rear LED taillights for r33 GTR, bnib, $499 for the pair
26) R33 black Nismo 320kmh 11,000 RPM gauge odometer cluster combo meter, 24810-RN595, $599
27) Momo Race Tuner Series Steering Wheel, leather, aluminum, quick release with BOSS kit, $175
28) R33/R34 GTR Mines Dynamic two-way adjustable, damper coilover, with external reservoir, 22k/20k Swift springs, new condition, revalved by Haas Racing in Illinois, $1995
  • 4 months later...
Updated list:
Prices in USD.
Massive skyline parts for sale
1) APEXi N1 Pro Adjustable Dampers Coilover for Drag racing, 9" springs, 9k/8k spring rate, for r33/r34 GTR; Apexi rebuilt it to new condition ($2500 msrp) $995
2) Brembo 2-piece 332mm = 13" front rotors (pair) for F50 Big Brake Kit $850; used like new
3) Seibon CF R33 GTR Jun style hood $599; used
4) r34 GTR rear trunk lid (damaged, someone tried to pry open trunk) $25; used
5) Lexus SC300 leather steering wheel with airbag $75; used
6) r33 signal auto drag spoiler $295; used
7) Hawk Brake pads HB209F .583 for Honda Civic HPS compound $44; new
8) Centric standard brake rotors #121.42013 for 1990-1992 Infiniti M30 $39 for the pair; bnib
9) Factory r33 GTR strut tower bar $75; used, excellent
10) Hks version ati race damper #916060 (hks pulleys and bracket not included), $295, used, excellent
11) r33 GTR driver side door card aka panel (ok condition), used $20
12) random gtr engine parts: alternator, fan, intercooler hoses, baffle, valves, pistons, r34 CAS (for parts), tension rod, control arms, make offer
13) R33 GTR oem front & rear sway bars, used, excellent $75
14) Greddy aka trust 80mm intercooler, 300x100x600, used, $895 for r33 GTR
15) Qest Japan rear LED taillights for r33 GTR, bnib, #qj-c303, $650 for the pair
16) R33/R34 GTR Mines Dynamic two-way adjustable, damper coilover, with external reservoir,brand new front pair of Cusco pillow balls, 2 sets of springs and helper springs, 22k/20k and 12k/10k Swift springs, new condition, revalved by Haas Racing in Illinois, $3500
17) r33 GTR Oem 1995 (has scrapes) $99, Oem 1998 (brand new) $450, Gracer (brand new) $395, front chin aka lip aka bumper spoiler, or $699 for all 3 lips
18) Nissan oem skyline r33 GTR windshield wiper motor brand new in box, $75
19) Nissan oem climate AC control unit, r33 GTR, used, $35
20) Kazama #xkmr1170 Nissan S and R chassis subframe spacers aka member rigid collar, brand new $75
21) Peak Performance front adjustable tension rod, r33 GTR, like new, $99
22) Authentic A'pexi El meter gauges with mounts and control unit. Wiring harnesses and sensors not included. You can buy them direct at apexi-usa.com. Meters are Water temp, exhaust temp, oil pressure, fuel pressure and oil temp. Like new. $375
23) oem black bcnr33 taillights, left right set, $99 used. Good shape.
