Big Hp RB30/26 engine for sale. New and unused. Still wrapped up.
RB30 bottom end, A8 turbo block machined and fully prepped and assembled.
Line bored, honed, oil control mods and head stud holes tapped out to 12mm.
Tensioner bolt relocated for twin cam head.
Arias ceramic coated forged 86.5mm pistons.
Spool H-Beam Rods
Crank lightened, linshed and balanced with extended collar fitted.
ARP main studs, ACL race bearings.
New knock sensors and welsh plugs fitted.
4wd sump and adapter.
RB26 Race head
Full CNC and hand port.
Head clearanced for larger cams.
HKS 280 degree cams 10.2 lift
HKS springs.
Jun Titanium retainers, bronze valve guides.
Supertech 1mm OS valves. Nitrided intake and inconel exhaust.
$12,000
Unfortunately have to sell due to purchasing a business, so making money has to now come before spending it.
Located Melbourne
Brad 0418 355 095
https://www.sau.com.au/forums/topic/457651-fs-big-hp-rb3026/
Hi just to be clear it's an A8 block yea? Because that is the turbo block which drops the compression too low for a twin cam head. A6 is what people use. Hopefully just a typo
The block doesn't affect the compression, it's the pistons that matter. He's not using stock pistons.
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
