Hey All,
Yesterday I blew an ignition fuse while I was out and about. Managed to swap it out with the ABS fuse to get home, but now need to replace it (and realistically, all the others).
I stopped in at Supercheap Auto, but they didn't have any... Any idea where to buy them from?
https://www.sau.com.au/forums/topic/457673-replacement-fuses-where-to-buy/
They're called PAL fuses. There's tons on ebay.
Thanks mate - That was a huge help, I found some on eBay from the UK and ordered them.
Just in case anyone searches the forum for similar in the future, here they are;
http://www.ebay.com.au/itm/SLOW-BLOW-FUSE-PAL-STANDARD-LOCKING-CLIP-TYPE-JAPANESE-GREEN-30-AMP-NISSAN-/301653193029
http://www.ebay.com.au/itm/SLOW-BLOW-FUSE-PAL-STANDARD-LOCKING-CLIP-TYPE-JAPANESE-BROWN-25-A-NISSAN-FUS2525-/301640152915
Dont meant to hijak but what about the relay's?
Found my Horn wasnt working and open the box and the relay is missing :verymad:
Does any body know what AMP's it is? I'm guessing its a 3 pin or some sort
My google skills are failing me
Thats what I'm hoping, just not sure on size, was hoping some one could check their R33 and see. The slot looks like its 3 pin
Prob buy this tomorrow and see how it goes
http://www.supercheapauto.com.au/online-store/products/Tridon-Mini-Relay-22-Amp-3-Pin.aspx?pid=293185#Recommendations
Thanks
Any idea on the AMP's, can seem to find anything from google on this relay
I guess it shouldnt be the flasher type?
I see this one, looks close in size and pins
http://www.supercheapauto.com.au/online-store/products/Tridon-Electronic-Flasher-Relay-Unit-12V-3-Pin-Load-Sensitive.aspx?pid=293191#Recommendations
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
