Hi Guys,
Could someone please confirm the date of this service (I suspect it's August 31 2013).
Does this mention anything about a timing belt replacement?
A general translation would be appreciated.
Cheers... Bob.
It's a sticker which indicates to a subsequent owner that maintenance should be carried out at regular intervals.
The top paragraph is about watchfulness of engine and running gear maintenance.
The bottom paragraph is about watchfulness of heater, air conditioning and filter maintenance.
The Kms at the bottom right is the figure travelled up to the date of exchange. And the exchange date is the 31st August of the 25th year of the Japanese calendar.
Hope this helps says Maria.
  • Like 1
Thanks Terry,
So........... "Date of exchange"......... Last service completed?
25th year of the Japanese calendar = 2013?
Ta......... Sorry I'm a bit slow so please type slowly.
Bob.
The stickers only for cabin/pollen filters, it explains what it does and says nothing about the engine or other mechanical gear maintenance
It also says that the cabin filter should be changed yearly or every 12000km whichever comes first
As for the exchange date- it's when it was last done, but it's due for a new filter according to the recommendation on the sticker anyway since we're in 2015 already
Edited by chiksluvit
  • 2 months later...
does anyone know what these are?
21022157179_b3411ca0f8_c.jpg20150907_141153 by Oliver K, on Flickr
20585587314_6ef1431453_b.jpg20150907_141205 by Oliver K, on Flickr
21210710295_8df59ff820_b.jpg20150907_141236 by Oliver K, on Flickr
21210709715_c835596833_b.jpg20150907_141242 by Oliver K, on Flickr
thank you in advance!
I know what the last one (placed on the underside of the bonnet) says.
It tells how the car has beautiful lacquer paint and to be extra careful when using anything that may damage said finish.
In other words, no harsh chemicals when washing the car.
you're thinking of these stickers
yes they are different pollen filter stickers.usually located in the glovebox. they state the 12000kms you defined the OP's sticker supposedly said.
Edit: shit sorry, i didnt see the 12,000kms bit at the bottom of OP's pic. there you go.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
