Hi all
Recently installed some new gauges on my GTT and saw there was nothing (that I could find) on wiring them up correctly so decided to make a little post to help anyone out in future
There's a pic of the stock wiring loom. The green/yellow is a 12v power line which you connect to so you don't blow any fuses in your lighter and the red wire with purple strip (third from the top) is your headlight switch.
Strangely I couldn't find a strong ground so I just hooked up a wire to this bolt which is visible once the A/C unit is removed
For the ignition wire I just spliced into my blue/white wire from my head unit but you can also do this with your ignition or lighter, I just found this the easiest to do
Lastly I SOLDERED and HEAT SHRINKED all the wires together and made sure not to do the old twist and tape that so many of us are guilty of. Alternatively you can crimp but as temp is relatively low under the dash board I don't think it matters what you do
Hope this helps and if anyone wants to know how to do the full install feel free to comment/pm me :)
  • Like 2
https://www.sau.com.au/forums/topic/457708-correct-way-to-wire-gauges-r34-gtt/
Not sure about the wire colours, but here is the pinouts for the ign, illumination and ground feeds. Heaps easier than messing around with getting the ciggy lighter feeds, and earthing from the deck bolts, but top work for trying.
Edited by sleptema
That diagram sure does help! I just thought to write this up for anyone who isn't too good with wiring diagrams or multi meters that wanted to DIY install some gauges without all the hassle
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
